question about wiring
Old Apr 24, 2007 | 09:46 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
how did you guys run your 4 guage wire to your battery? did you make a new hole for it or what? is there an area where i can push it through the firewall>/
Old Apr 25, 2007 | 07:33 AM
86camarokid's Avatar
Car: 86 Camaro
Engine: 2.8L mpfi V-6
Re: question about wiring
if you run your wire on either side of the car there are rubber garomets you can push the wire threw, on the driver side it up by the fuse box and on the passenger side you can just run it with the main wiring harness for the computer threw the firewall... or if you want to waste lots of time and make a new hole you can do that too but i wouldn't...
Old Apr 26, 2007 | 02:58 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Be sure to fuse the wire as close to the battery's positive terminal as possible.
Old Apr 26, 2007 | 02:54 PM
Car: 86 Camaro
yea deff lol makes it easy to change if you would ever happen to blow it...
Old Apr 27, 2007 | 02:39 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
You want the fuse less than 2 feet from the battery if you can manage, the goal is to stop the car from catching on fire. It doesn't take much time to drill a new hole at all, there's some decent spots on the firewall for this purpose and the firewall is pretty thin.
Old Apr 27, 2007 | 03:26 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
I RAN MY 0 GAUGE WIRE THROUGH A GROMET HOLE BY THE FUSE PANEL. BUT I PUT MY FUSES IN MY CENTER CONSOLE BECAUSE I HAVE A DISTRIBUTION BLOCK. THE CONSOLE IS ALSO WHERE MY DIGITAL EQ IS, SO I CAN GET TO THEM VERY EASILY!
Old Apr 28, 2007 | 09:07 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
TURN YOUR CAPS LOCK OFF.... i ran mine with my antenna wire on the passenger side behind the kick panel
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
