what type of amp?
Old Apr 27, 2007 | 04:49 PM
92fireformula's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tpi
what type of amp?
I have 2 12" kicker l7's and i am wondering what type of amp i should get to run them?
Old Apr 27, 2007 | 05:10 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Re: what type of amp?
http://www.crutchfield.com/S-LQEJ1Q1...000&tab=review
Old Apr 27, 2007 | 05:52 PM
speedracer0626's Avatar
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
Profile amps are sh#!. Here ya go for some serious thump I mean you got L7's come on got to do it.
http://www.mmxpress.com/ppi/precisio...amplifiers.htm
Old Apr 27, 2007 | 06:15 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
http://www.techronics.com/index.cfm?...roduct_ID=3803
wire it to a 1 ohm load ,
http://mobile.jlaudio.com/support_pages.php?page_id=161
2 DVC drivers with Voice Coils in Parallel / Parallel
thats if you have 4 dual voice coil subs not 2 DVC
for a tye of amp you want a mono D amp that can do 1000-1500/1600 RMS into 1 ohm , that way each speaker will be getting just over there max rms setting which shouldnt hurt them just dont go crazy with them first sat your gains just a tib bit lower which you shouldnt even need to do
good SPL sub them l7's make sure you got them in a nice ported box
Old Apr 27, 2007 | 07:26 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
GO WIT TWO KICKER 1200/ 1. PUT ONE ON EACH PUT EM BOTH @ 2OHMS AND LET IT RIP. I JUST GOT RID OF 4 12INCH L7'S THAT HAD 2 JL 1000/1 ON THEM AND THEY SLAMMED!....DONT 4GET THE HIGHS THOUGH U'LL NEED EM!
Old Apr 28, 2007 | 09:01 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
memphis, us amps, kicker amps.. just get an amp thats a little over the rms rating of the subs at whatever ohm you are going to run them at
Old Apr 28, 2007 | 10:14 AM
Engine: 5.0 tpi
thanks for all the info. i am going to check them all out
Old Apr 28, 2007 | 11:25 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Older USAmps, older Orion, JL Audio and Rockford PowerSeries are good IMO. You want to look first at how they are to be wired. Looking at what you have, probably gonna need an amp thats 2ohm stable mono or bridged. So youll be looking for a MONO amp as already mentioned. Now look at the RMP power rating. Pay no attention to the PEAK power listing. Thats not a true rating and its not industry regulated. You will want to match at least by the RMS rating on the subs or get a slightly bigger amp than that so you can be conservative on the gain. Also, most amps of this magnatude, if they are true, will need at least a 4ga cable for power and ground. Most of them will have a large terminal set on the side to accomidate this. And dont get a 4 ga power kit that splits off to 2 8ga wires. If you plan on multiple amps, get seperate power kits or a 1/0ga to 2 4ga. Sub amps require alot of current flow when being jammed on. Thats just the nature of powering the speakers large motor structure and the effort taken to reproduce the lower frequencies. Good luck in your quest and dont skimp on the power kit or RCAs.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
raymondandretti
Sep 27, 2015 06:43 PM
