Need a good ground...line noise
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
'88 T/A
I have a feedback/whining issue on my newly installed system (New Kenwood HU, 4 channel amp, and Alpine 6x9's). The whining doesn't rise and fall with the engine and isn't there at all when the car is on, but not all the way on. I can turn up the HU and it will eventually drown out the sound, but at low volumes, it is still quite audible.
I am only pushing the 6x9's on the 4 channel amp. The wires are all the same size, everything is brand new, and all is connected and shrink wrapped. I did a SEARCH and came up with some ideas and some useful info. I think the problem may be either my RCA's or my ground.
Here is what I've done so far:
Moved the ground 3 times. 2 different bolts near the hatch pull down, and one where the T Tops anchor to against the back wall. Same problem with all positions.
I have plugged in one side of the RCA and got noise on that speaker. Unplugged it, then plugged in the other side with the same noise. Tried the second set of preouts in my HU, same result.
Could you guys provide some input on where to ground or if my RCA's are the problem?
Car: '91 Pontiac Formula w T-Tops
Engine: 5.0 V8
Transmission: AT
Re: Need a good ground...line noise
Are you trying to ground the amp or the deck?
For the amp I ran the ground right under th paneling to one of those clips the bolt on. The ones that a t-top bag would clip to. I can upload a pic if you don't know what i mean. EDIT: I saw you already tried this. Try bolting the ground between the hook and the body. Worked for me, if you didn't already try it.
For the deck, theres like an expose bolt in the console opening. I just bolted the ground to that bolt. again, I can upload pics if needed.
Car: '91 Trans Am
Axle/Gears: 3:42
I'm trying to ground the amp. THe HU seems to be okay.
No need for pictures, I understood what you meant. I grounded to the T Top bracket thing like you mentioned, no such luck. I'll try to ground to the one under the carpeting on the deck tomorrow for S&G's.
I'm really beginning to think it is the RCA cables, but I am still unsure if I just suck at grounding this time around.
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
i had a similar problem with my 4 channel pioneer amp, turns out i needed to bridge the 4 channels down to 2 and adjust the gain, after that it works perfect
Car: 89 IROC-Z
Engine: 355 TPI
The HU ground is just as important as the amps ground. If the amp is properly grounded and the HU's ground is noisy then it's going to send the noise out the RCAs for the amp to amplify.
Id the HU ground in the harness? If so move that to a solid chassis ground.
Car: '91 Trans Am
Axle/Gears: 3:42
Thanks for all the advice so far!!
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I would also try a different set of RCA's...
Make sure the deck is also grounded good...
Raf
Raf
Car: '91 Trans Am
Axle/Gears: 3:42
Well, I reground the cd player to a better place, moved the RCA's further from the Power wire (More than opposite sides now), and ground the amp in a trial and error placing. All was well up until about 4 hours afterwards.
I still have the static cable sound!! I'm definitely placing the blame on my ground now, but I still can't get a good place. I've tried grounding to the electric pull down, a spot on the chassis near it, and on the t top hook area. All result in a no go.
Can I ground to those nice screws that hold the bumper in place? I know there is a rubber gromet in there, but I'm unsure.
Try a ground loop isolator... Radio Shack carries them...
Raf
Raf
Car: '91 Trans Am
Axle/Gears: 3:42
Ack, all that work moving the RCA's far opposite from the power foiled where I ran them near each other for less than a foot into the pass rear interior body panel!
All I had to do was seperate them on either side of the inflata-spare and BAM- no more aggrevating sounds.
I appreciate everyone who helped me out with sorting out my problem, you guys rock!
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 11, 2015 10:11 PM
