cd player wiring help!
Old Apr 30, 2007 | 11:06 AM
Form88's Avatar
Car: 1988 Firebird Formula
Engine: 305 L03
Ok. Im having alittle trouble installing my new cd player. Its a cheap Alpine(CDE-9870). My problem is that i have 9 wires coming from the radio harness(no connector), and not entirely sure what they are. I checked multiple wiring schematics and after trial and error it ended in error.
The wires coming from the harness are as followed:
Black
Yellow
orange
Dark gray
Grey (speaker)
Brown (speaker)
Dark green(speaker)
light green(speaker)
Dark brown
The new Alpine cd player:
Blue- power ant
Blue/white- remote turn-on
pink/black- audio interrupt in
orange- Illumination
Red- Ignition
Yellow- battery
Black- ground
and the speakers are:
gray-(+) RF)
Gray/black- (-)RF)
Violet/black-(-)RR)
Viloet-(+)RR
Green-(+) LR)
Green/black-(-) LR)
White/Black-(-)LF)
White-(+) LF)
.....So what goes with what wire? Also, The car is and 83 trans am.
and I am aware that some wires are not going to be used. I greatly appreciate any input.
Jim
Old Apr 30, 2007 | 11:24 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Re: cd player wiring help!
http://www.installdr.com/Harnesses/GM-Wiring.pdf
Very accurate. I just used it over the weekend.
Old Apr 30, 2007 | 12:57 PM
j dezzy's Avatar
Car: 87 TA
The car's harnes is as follows: Orange is your hot, yellow is your ACC, black is your ground. you can find your speaker wires by hooking them to a power source of some kind and listening to what speaker crackles. as for the stereo, there should be a sticker on the top that tells which wire is for what.
Old Apr 30, 2007 | 02:04 PM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
kinda exactally what i said on epfba :P
Old Apr 30, 2007 | 05:21 PM
Form88's Avatar
Engine: 305 L03
ok i hooked up the 12v battery and ignition, dimmer, the ground, the speakers and i get no display on the head unit. I believe all the necessary fuses are ok. I got that "CD eject/recieve" sound when i turn on my accessories, but then the screen display doesnt come up. I am getting 12v from the orange and yellow wires, but not from the gray dimmer wirer from the factory harness, not sure what the problem is...
Old Apr 30, 2007 | 05:26 PM
j dezzy's Avatar
Car: 87 TA
you shouldn't need the dimmer wire from the factory harness. Just cap it off and get it out of the way. make sure that you've got the 12v and the ACC wires hooked up to the right wires on the stereo.
Old Jun 1, 2007 | 05:21 PM
geehumshriber's Avatar
what is the username and password for this site?
Old Jun 1, 2007 | 05:50 PM
j dezzy's Avatar
Car: 87 TA
What?
Old Jun 1, 2007 | 05:52 PM
The password for the installdr.com site, it's password protected.
Unless you have the diagram for an 82 Camaro stereo... (the car wire label, so I know how to wire on my harness)
Old Jun 1, 2007 | 06:11 PM
What do you mean by ACC, is that ignition or battery?
Old Jun 2, 2007 | 08:51 AM
j dezzy's Avatar
Car: 87 TA
ACC is accessory power, the ignition.
I just went to the site in question and didn't need any kind of password...
Old Jun 2, 2007 | 10:35 AM
Password protection must have been removed last night. Amazing.
Old Jun 2, 2007 | 10:36 AM
j dezzy's Avatar
Car: 87 TA
lol. they must've had a flaw in the site or somthing. good luck.
Old Jun 7, 2007 | 10:06 AM
camaro91boy's Avatar
Car: 95 z28 camaro or 92 k5 Blazer
Engine: LT-1 fo the Z. vortec fo K-5
Transmission: 4L60E=Z junkR4=K-5
Axle/Gears: 3.43=Z / 3.73=Blazer
get a haynze manual on your car they cost around $16 in the back they show the wiring harness. if your to strung out of cash try a 9 volt battery to the wires that are solid then same color with a black line. theses are your speaker leads. with the 9 volt trick the speakers will crackle and give you an idea of what speaker it is. your solid color is + black line is- for your speakers. the yellow is acc witch kills your power with the switch. orange is constant it should be red but this is what keeps your settings and last solid black is neg or ground. hopefully this works if not ill get back with you when i can see my manual.
oopse tie the orange together with acc on radio
Last edited by camaro91boy; Jun 7, 2007 at 10:07 AM. Reason: Automerged Doublepost
kairles
Oct 26, 2015 09:13 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
