putting regular speakers in bose panels
Old Oct 16, 2007 | 11:21 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Anyone ever put regular speakers in bose kick panels and in the trunk liftup lid? I'de like to use what I have to get 8 speakers in my car.
Old Oct 16, 2007 | 11:38 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: putting regular speakers in bose panels
I've placed 4" speakers in the bose kick panels. Had to use a dremel to take off some of the plastic to fit them. You probably won't find a speaker that will fit the kick panels without some modification.
Old Oct 16, 2007 | 04:55 PM
Jproz1167's Avatar
you have pictures of this?
Old Oct 16, 2007 | 04:58 PM
Jays92Camaro's Avatar
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
Did you gutt the insides by removing the amps? How did they sound?
Old Oct 17, 2007 | 06:26 AM
naf's Avatar
naf
Can't get you pictures, already recovered with the carpet. Didn't remove or re-use the amps. They were likely lower output than the feed from my deck. I did hook up the (new) speakers through the amps on the workbench and couldn't tell any difference.
I used 4" Kicker 2-way speakers don't remember the specific model.
Old Oct 21, 2007 | 11:29 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
How long ago was that? I've been looking and so far, have not found anything that would not require major modifications to the kicks.
Old Oct 21, 2007 | 12:24 PM
naf's Avatar
naf
Last Summer? If you've pulled the factory speakers out you'll see why it would be difficult to find a replacement speaker that will mount without breaking out the dremel. The kickers are covered in carpet though and you could even cut out the grill and mount replacement speakers from the outside of the plastic enclosure.
Old Oct 21, 2007 | 12:39 PM
Engine: that I like
Yes, I've taken the pass side one apart which seems to be deeper than the driver side. I haven't been able to find anything that will fit without cutting a large hole in the back of the panel. I've thought about it, but I really want to keep them mounted behind the factory carpet.
Old Oct 21, 2007 | 02:18 PM
naf's Avatar
naf
If they don't have too much profile outside the box, you could still cover them with carpet. I'm thinking one of mine was like that.
Old Oct 29, 2007 | 03:35 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
On my 1991 Z28 w/the BOSE I had to break out the hole saw on the drivers side kick panel for my Infinity Reference 3.5 to fit but on the passenger side there is a completely different speaker and setup so the box was deep enough for them.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
