amp power
Old Oct 17, 2007 | 05:05 PM
popballz's Avatar
Car: 89 firebird
amp power
it says to run the power cable away from the ignition, so i was going to put it on the passenger side but there is a lot of stuff in the way, is it ok to run it on the driver side?
thanks
and is there a hole already somewhere for me to put it threw or so i have to drill one?(89 firebird)
Old Oct 19, 2007 | 05:13 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: amp power
i would run it on the passenger side, the batteries there. If you run it on the apssenger side theres a rubber gromet for the antenna that runs into the fender, thats what i used. Just run your RCA's on the opposite side of the power
Old Oct 19, 2007 | 09:15 PM
popballz's Avatar
Car: 89 firebird
Re: amp power
ummm, the battery is on the drivers side, and i also just did it on the drivers side and the ignition didnt affect it at all....
Old Oct 19, 2007 | 10:37 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: amp power
The battery is on the passanger side on my car? Does it differ from year to year?
Old Oct 22, 2007 | 05:13 PM
TheBandit's Avatar
Engine: Poncho 350
Re: amp power
i guess so because my 86 had it on the passenger side so i assumed they all did
Old Oct 24, 2007 | 03:39 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: amp power
driverside for me and when i had my system i ran the wires along that side never had a problem. took out system put in wifes car ran power down d-side still no prob
Old Oct 25, 2007 | 06:38 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
Re: amp power
there is a guy who competes in IASCA SQ and he has all his cables bundled together (did it to show there wasn't a difference if you use good cables)
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
sailtexas186548
Aug 24, 2015 10:11 PM
ZsTransAm
Aug 11, 2015 07:30 PM
