Wiring Question
Old Nov 2, 2007 | 10:24 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Wiring Question
I got a Delco radio out of a trans am the other day at the junk yard. To replace a Kenwood that the previous owner put in. But, of course the wiring harness was gone. I know that I need the typical 12 pin Delco harness. But, I don't know what the brown and orange wires coming to a 2 pin connector are? Also, what is the black wire with the single connector going to? THANKS
Old Nov 3, 2007 | 12:10 PM
Re: Wiring Question
bump
Old Nov 3, 2007 | 01:03 PM
Re: Wiring Question
bump
Old Nov 3, 2007 | 03:36 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
Re: Wiring Question
the orange is typically the memory wire (lighter fuse) brown is dimming (dims the radio when you turn on lights) black is typically a ground. You can use a multi meter, or a good test light to find what the wires do also (check if power with lights on, or with the fuse pulled)
Old Nov 3, 2007 | 05:16 PM
Re: Wiring Question
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
