How can one blow an amp?
Old Nov 7, 2007 | 06:32 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I'm getting a replacement amp tomorrow for my Audiobahn A4004V that recently blew. Whatever happened inside I don't know, but I was popping 30 amp power cable fuses instantly upon installing them. There was zero oms between the power terminal and the ground terminal, so hooking it up was basically grounding the positive battery terminal. It blew after 3 months of being installed. If the problem is with my SETUP, I would like to FIX it before installing the new amp.
Its driving two Infinity 4x6 speakers up front and two Infinity 6x9 speakers in the rear. The volume was down when it blew.
I have it positioned atop the rear hump, on the right side, right behind the head of the person sitting in the rear right side seat. It is ALWAYS under the cargo shade, and my back window has some super dark tint. Could it still be too much heat? The sun didn't hit it once.
The deck is a Pioneer DEH-2700. The Preamp output voltage for this deck is 2.2v, and I had the amp level set accordingly. (about 70% based on Audiobahn's instructions)
Any guesses on why it blew? Defective product?
Old Nov 7, 2007 | 06:37 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: How can one blow an amp?
seems to me to be a defect in the amp itself not your set up, i would just hook it back up and go to town with it
Old Nov 8, 2007 | 03:57 AM
00maxipad's Avatar
I would possibly say that maybe the speakers were different OHM level than what the amp was putting out at that wiring... Sounds like what I did with my Audiobahn amp my subs were different ohms than my amp...and it blew..
Old Nov 8, 2007 | 08:42 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
it being an audiobahn it was probably internal, they just had the company that made their stuff close shop, and are using 2 or 3 different manufacturers trying to find one that can make them right
Old Nov 8, 2007 | 12:45 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
The speakers are Infinity Reference, 4 ohm impedance I'm pretty sure. Do I have to do something special for these with my amp?
Old Nov 8, 2007 | 02:35 PM
cdoyle's Avatar
If everything was hooked up properly, it's most just the amp.
This is one of the reasons I tell people to avoid them, they are one of those companies that go after the 'bling' with shiny subs etc, but the quality inside their products are questionable.
Old Nov 9, 2007 | 07:12 AM
archemedes's Avatar
Engine: 3.8 sc
and the price is high for what you get
Old Nov 13, 2007 | 01:27 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Every now and then i get a whiff of mild electronic smell from my amp. I do now and i did with the old one. Is this normal? Doesn't smell like burning.
Old Nov 13, 2007 | 08:52 AM
archemedes's Avatar
Engine: 3.8 sc
there are some coatings that kind of burn off when powered up sometimes, but I rarely smell anything
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
Fanatic1074
Oct 2, 2015 03:47 PM
raymondandretti
Sep 27, 2015 06:43 PM
