CAN YOU WIRE THESE SUBS TO THE SAME AMP??
Old Dec 20, 2007 | 12:30 PM
Audiobahn07's Avatar
Look I have 2 Dual 6 Ohm Woofers And 2 Dual 4 Ohm Woofers.. and i was wondering if i could wire these to the same amp??? could i wire my 6 ohm woofers down to the same independence or Close to it.. i was reading something saying u can only wire Dual 6 Ohm woofers to 3 Ohm Or 1.5.. I dunno much about the Dual 6 woofers.. can some help me out.. if this is possable.. draw me a diagram?
Old Dec 20, 2007 | 08:29 PM
Re: CAN YOU WIRE THESE SUBS TO THE SAME AMP??
2 Help you out a lil bit il give you a lil more information on the electronics i have..
2000 watt 2 Channel Legacy series 2 Amp..
2 Dual 4 ohm Audiobahn 12" woofers.. 800 watts max both 2gether 1600 watts
2 Dual 6 Ohm American Bass 12" Woofers, thinking about 1000 watts together.. help you out any?
Old Dec 20, 2007 | 09:21 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
if you must use those subs i would say use only the 2 audiobahn and **** can those other two. Build a ported box for the two subs and it will hit harder then hooking the other 2 up. Legacy never pushes out what they say they will and noramlly the rating is rated at 1 or 2 ohms. My sugestion is get better stuff and you will only need one or 2 subs to reach what you want. I have one jl10w7 ported and it hits and sounds better and gets louder then most 12's. Not trying to be a one upper just my opinion and suggestion
Old Dec 20, 2007 | 11:28 PM
can u design a ported box for me .. or anybody here with this???
My Trunk Measurements
15 1/2 Height length 43 1/2
Thunderbird Measurements
Vb = the internal volume of your box - 41.585 (ft3 )
Fb = the tuning frequency you want - 18.78 Hertz
F3 - the frequency that the response is down by 3 dB at. - 12.84 Hertz
Fs - 37.4 Hertz
Vas - 2.45 (ft3 )
Qts - 0.82
Drivers - 2
2 12 Inch Audiobahns
1600 Watts together!
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ZsTransAm
Aug 11, 2015 07:30 PM
