need the most power!!!!!!!
Old Feb 7, 2008 | 02:11 AM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i have a pioneer 5200t amp 760watt amp and a pioneer champion series 4 ohm dvc sub rated at 400 rms. the amp puts out 380 watts at 4 ohms bridged, how do i wire the sub to stay at 4 ohms to take the power?
Old Feb 7, 2008 | 04:10 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Re: need the most power!!!!!!!
Here you go. Hope this helps.
http://img297.imageshack.us/my.php?i...riesdvc7kb.gif
http://www.pioneerelectronics.com/PU...GM-5200T?tab=B
Your amp shows that it can run at 8 ohms bridged.
Old Feb 7, 2008 | 04:37 PM
demon138's Avatar
i have it at 8 ohms right now and it doesnt seem all that loud, but its in a sealed box. i want to keep it at 4 ohms for the full 380 watts.wouldnt it be only 190 watts at ohms?
Old Feb 7, 2008 | 05:29 PM
Car: 91 RS
Engine: 305 TBI
This may seem like a silly question but, are you using the Left Pos. and Right Neg. amp terminals for bridging?
Do you have the speaker wired like the link shows?
Amp Pos. to 1 sub Pos.
Amp Neg. to 1 sub Neg.
The leftover Sub Pos. & Neg. Jumper together.
Old Feb 7, 2008 | 08:54 PM
terrorhertz's Avatar
Car: '88 IROC
Engine: 305 TBI LO3 for now
You didn't specify the model # of the subs. Is this the correct sub?
http://www.pioneerelectronics.com/PU...t?format=Print
This sub is offered in 2 4ohm coils or 2 2ohm coils. If you have one sub with 2 4ohm coils then you can't wire it for a 4ohm mono/bridged load. You can only get 2 or 8 ohm load out of one DVC sub.
If you have 2 2ohm voice coils then you can have 1ohm or 4 ohm with a single sub.
I you have the 4ohm per coil version then all isn't lost. You can still get a 4ohm load if you have 2 subs with 2 4ohm coils. Just wire the 2 coils on each sub in paralell then wire for 2ohm then wire the 2 subs in series for a total of 4 ohms.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
