JVC KD NX5000
Old Apr 6, 2008 | 12:20 PM
J.Cutta's Avatar
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
JVC KD NX5000
I have the jvc the model before this one and love it. I always wanted a built in hard drive and the navigation is a plus. But this unit requires a hook up to the VSS wire and the back up light wire in order for the navigation to work. The link below is a detailed page that explains more about the head unit in detail when you hover the mouse over the picture. Are those wires going to be hell to find?
http://www.rpi.edu/~travaa/tps3.html
Old Apr 18, 2008 | 12:41 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: JVC KD NX5000
vss wire will be behind the cluster so its no biggie but the back up light needing to be hooked up i question, but if it really needs it there is a little switch located around the shifter assembly (i think). i think the back up light needing to be hooked up is if you have a rear view camera, that way the screen knows to switch to it, if you dont have that option dont hook it up otherwise u will probably get annoyed everytime u put it in reverse and u have a blue screen
Ducati900ss
Sep 2, 2015 09:05 AM
silver89Rs
Car Audio
Nov 28, 2001 10:36 PM
elevario
Car Audio
Oct 17, 2001 07:53 AM
CamaroZ_85
Car Audio
May 16, 2001 01:59 PM
CamaroZ_85
Car Audio
Mar 16, 2001 10:25 AM
