Do I need an extra battery?
Old Apr 13, 2008 | 05:19 PM
Son of Anarchy's Avatar
Car: 1987 Camaro IROC-Z
Engine: 383 Carbed
Heres the deal, I bought a Sony Xplod 1000 watt amp, and two "12 1200 watt subs. Along with I think the 600 watt 6x9's. Do I need a capcitor and a battery, or what?
Old Apr 13, 2008 | 06:11 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: Do I need an extra battery?
Is that peak power? If it is then I would need to know the continuous power to be sure. A capacitor will never hurt, but if you get another battery it will just die because it will have nothing to charge it unless its somehow hooked up to the alternator?
Overall I dont think you will need to do anything. But if you get it all in and your lights are flickering or something, then just go grab a capacitor.
Old Apr 13, 2008 | 06:13 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Seeing as that audio is my thing, I'll answer this question. If you don't have to run the fans alot or the rear defogger, you'll be okay without a battery, and your lights might dim when the bass hits but you'll be okay. If you play the music at night on a warm day, get a battery. A cap isn't worth buying. Also get a deep cycle battery like an optima or kinetic. Make sure that you have excellent grounds and that you don't use cheap wire. That should solve everything. Any questions, feel free to ask. PM me pics of the install and maybe I can give you some pointers.
Old Apr 13, 2008 | 08:15 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Also, if you do decide on a second battery for your audio system, it's not necessary, but you might want to isolate it from your starting battery. I have a diode isolator (similar to an RV with hotel loads on a second battery) in my system which allows the alternator to charge one or the other battery as the demand dictates.
Old Apr 25, 2008 | 10:04 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I had that set-up in my previous car (alternator --> isolator --> two seperate batteries). What also worked great is that when having the secondary battery dedicated to the stereo, I could run my stereo when parked worry free. If the battery went weak or dead, the other battery was uneffected. I could still jump in, start my car, and drive away.
A 2nd cool thing is, if you know what your doing (must be done right or you may cause a dangerous short), you can boost yourself if you're main battery does go dead for some reason.
You can't do either of the above with a cap.
Old Apr 25, 2008 | 10:09 PM
Axle/Gears: 3.08
My above post doesn't say anything about whether you need a second battery, just some points about that set-up.
As Timothayyy said, you might not need anything at all, or maybe just a cap, depending on what happens (as he mentions).
Old Apr 28, 2008 | 06:06 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Haha. No, you absolutely do not need an extra battery. You have WAY to small of a system. A capacitor will help your lights from flickering at night, but even a cap won't make much of a noticeable difference.
Your fine bud, no worries.
Old Apr 30, 2008 | 11:18 PM
crazyryceman's Avatar
Car: '90 Firebird Formula
Engine: 5.7L
how dangerous is a dangerous short? and how would i know it happened?
Old May 1, 2008 | 12:07 AM
REDTAIL's Avatar
Car: 86 iroc 92 rs parts car
Engine: 350 305
Transmission: t5 t5
Axle/Gears: 3:73, 3:08
no... but I would first up grade the alt. to 160-200 amp when you start running in to voltage problems unless you plan on running your system with out the car running.
Old May 1, 2008 | 05:15 PM
Al Hasse's Avatar
[QUOTE=Iroctopless;3732361]A 2nd cool thing is, you can boost yourself if you're main battery does go dead for some reason.QUOTE]
I have on a couple of occasions. I used a long set of cables from the rear to the front of the car (batteries are on the same side). Looking back, all I really had to do was undo one battery cable from the isolator and connect it to theother one, effectively paralleling the batteries.
Another idea to consider would be an isolator/combiner, which I've heard acts like an isolator in every situation except starting, then effectively combines the batteries.
http://www.hellroaring.com/
Old May 6, 2008 | 05:54 PM
3rdgen383's Avatar
Car: 91 RS
Engine: 383 Stroker 450HP
Transmission: TH350 3500 Stall no OD
Axle/Gears: 30 Spline Axles 4:10 gears
with that setup, you wont need a cap or a deep cycle battery. stick with what your car has.
Falcon50
Aug 22, 2020 03:26 PM
Night rider327
Oct 9, 2015 09:25 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
drumstixer
Sep 29, 2015 03:02 PM
