What size speakers can fit in the dash? Depth-wise???
Old May 16, 2008 | 02:46 PM
cregmonroe's Avatar
I know the 4x6 and 4" speakers can both fit in the dash but I was wanting to install these infinitys and crutchfields website states they wont fit but does not say the maximum depth... Does anyone know what it might be? If these wont fit anyone have some suggestions for good speakers that will or a way i can make em fit?
Old May 19, 2008 | 05:40 PM
asting's Avatar
Re: What size speakers can fit in the dash? Depth-wise???
you can always use a heat gun and a dremel to try and make them fit, but it depends on the year and model. what car do you have? (obviously a third gen, but which one?)
Old May 21, 2008 | 05:49 PM
cregmonroe's Avatar
It's an 89' rs convertible
Old May 21, 2008 | 06:56 PM
asting's Avatar
1.75" I think is the mounting depth. you could also use crutchfield to select your car.
Old May 21, 2008 | 09:37 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have 2.25 depth on my 5.25 component in the front of my 92 rs.
Old May 21, 2008 | 10:35 PM
asting's Avatar
like one or two threads down in this forum said an 89 has 1.75. Also, maybe post the speakers you're thinking about, and you can see if anyone else had issues with it. and Crytical. We have like the exact same car basically. And we both live in fl. Don't you love heat+our cars?
Old May 21, 2008 | 11:35 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Yea. The depth is not much at all, and from what I read, Firebirds have it even worse! I had to sell a set of two way 4x6's because they just wouldn't fit. I'd agree with the 1.75". With a depth that small, might as well go to walmart and get they're guaranteed factory fit Kenwood speakers. It'd sound better than stock at least.
Old Mar 12, 2010 | 07:23 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I know that 82 to 92 Camaros have a depth of 1 7/8inch stock and after market is 1 5/8 inch deep. This will cover just about all dash mount. Almost all speaker makers use the 1 5/8 inch deep. So realy all you need to do is find the brand you like and install. I have noticed that dash speaker room is tight in every 3rd Gen I have installed in and that would be a lot of them. Just take your time when going in with them.
Old Mar 14, 2010 | 04:40 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
FWIW I have an older set of Eclipse 4x6 2-ways and the driver side speaker magnet hits the plastic where the gauge cluster slips into. I need another 1/4" for them to sit flush and could have easily gained that by hacking away at the surrounding plastic.
I did not want to do that, however, and even though they sit up the dash pad fits overtop just fine. Sorry I do not know the mounting depth....worthless info without that.
So, even though Crutchfield may not say they fit you can be creative with different choices at your discretion.
toronto formula
Nov 10, 2015 06:17 AM
89lsc
Aug 14, 2015 04:58 PM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
