what would be a good amp to power these subs?
Old Jun 12, 2008 | 03:27 PM
DDT12's Avatar
two kicker comp 12" subs?
http://www.circuitcity.com/ssm/Kicke...oductDetail.do
Old Jun 14, 2008 | 12:18 PM
DDT12's Avatar
Re: what would be a good amp to power these subs?
can someone help me out? im new to car audio. =/
Old Jun 14, 2008 | 12:57 PM
Tony_B972's Avatar
Car: 86 IROC
Engine: 383 (in progress)
Transmission: tko 600
You need a 300w rms @2 ohm amp remeber its 300RMS not peak power and those are for a sealed enclosure so u need a sealed box w/ em. Also btw dont buy the expensive wires (monster)w/ that u dont need em get the cheap ones or go to wal-mart and get theirs it will save u some $
Old Jun 14, 2008 | 05:55 PM
hellsatan's Avatar
Car: 89 IROC
If every1 just bought the same amp as the subs it would be much easier (STOP MIXING COMPANIES IT MAKES IT VERY COMPLICATED IF YOUR VERY NEW AT THIS!!!).. Audio companies usally make their amps for certian setups of their line of products (JL audio for example 12w Sub [500rms] and 500/1 amp [500rms amp] its perfect... nice and simple) ... stick with kicker amps like Tony_B972 said and you should be good to go. Also I think you would need two of these amps to run two subs don't take my word I don't know a HUGE amount about power and junk.
Old Jun 14, 2008 | 08:04 PM
Tony_B972's Avatar
Car: 86 IROC
one should be perfect the speakers are listing the peak on the header is 300 the rms is 150 that times 2 is 300 the rms on the amp and ur right hellsatan most companies make matching pieces
RazorN8
Jan 7, 2022 11:44 AM
Brcharrelson
Aug 26, 2015 07:47 PM
InfinityShade
Aug 22, 2015 08:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
