I need help installing a new pioneer deck
Old Dec 31, 2008 | 01:33 PM
Brandondflaig's Avatar
I took out my stock radio/cassette player in my 89 camaro and i just need help with the wiring and installing of the new stereo
Old Dec 31, 2008 | 02:30 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: I need help installing a new pioneer deck
If the car still has the stock harness (I assume it does since you took out the stock deck), go to your local car audio store and get a GM to Pioneer adapter and splice it into the pigtail that came with your new deck. If you ask real nice, they may even splice the two together for you, then all you need to do is plug it in
EDIT: You probably will also need a GM antenna adapter to correct for the different size plugs...
Old Jan 6, 2009 | 11:33 PM
alscamaro89's Avatar
Car: 89 iroc
Axle/Gears: posi
i just put a pioneer system in my car and you can buy the adapter to fit from best buy. You can also buy a little adapter for the antenna too because the reciever in the pioneer unit is much larger than the stock antenna tip. I also bought 6x9s and 4x6s from best buy, and the dash install kit from best buy too. I spent a total of 90 bucks i think it was not including the 100 for the system itself. Very affordable doing it myself.
Old Jan 7, 2009 | 04:04 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
I just put a sony xlpod in my 88 gta. It was extremely easy once I figured out what wires are what. I just went to best buy and got the 1988-2004 GM harness and crimped my sony pigtail onto it. no problems what so ever. The harness was $23 though...
Old Jan 7, 2009 | 07:25 PM
ILUVMY89's Avatar
go to wal mart in the car audi section all harness for all types of cars are only 7 dollars never go to best nuy or others HUGE RIP OFF
Old Jan 7, 2009 | 07:55 PM
Car: 89 iroc
Axle/Gears: posi
i got 4 speakers, and all the hardware and adapter cords for 90 bucks at best buy... thats not bad seeing you can spend more than that on speakers alone...
Old Jan 7, 2009 | 08:26 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i might as well ask here.. when i turn my car off the radio doesnt go pff i have to hold the power button down and wait for it to shut off what is the power wire for the radio in a 91 firebird i have the pioneer red to the orange and red one in my bird but it just doesnt turn off with the car could it be a bad ground?
Old Jan 7, 2009 | 08:42 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
nope not a bad ground. If it was a bad ground it would most likely not come on at all. Seeing how its a pioneer there wiring colors are a lil different but it should tell you which is which on the top or bottom of the stereo. If you cut your factory harness then im sry but oh well. If you got the factor harness plug in tail then thats good. A red wire usually of thicker gauge wire is the constant wire. A yellow wire is the ignition hot wire. This is what will send the power signal to turn on and off your radio when you have your car in the run or accesory settings. Black is ground and the rest are for your speakers, remote turn on wire for amp, power attena, dimmer control, etc. Those depend on car.
I would check your igntion constant wire. If your radio is turning on and not turning off then you might have wired the radio so it has constant power. This would cause you to have turn it off manunally. Just post back if your confused.
Old Jan 7, 2009 | 09:06 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
^^Just noticed i said that red was the constant. I forgot our third gens its orange not red.
Old Jan 7, 2009 | 09:10 PM
Car: 1991 Trans Am
Axle/Gears: Stock
that makes sense i think there is a yellow wire just floating in the thanks for the help.
Old Jan 8, 2009 | 05:20 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
Old Jan 18, 2009 | 05:09 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
okay so in my 88 camaro, what wire is the power wire? i know yellow is ignition and black is ground, anybody with a brain knows that, but what wire is the hot? theres no red in this damn thing and it has like 3 different tails. i know all the colors of the speaker wires and everything, but what color is the power? is it the gray one????
Old Jan 18, 2009 | 05:42 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
It should be red or orange. I dont remember what 88's color code was. Its been a long time since ive worked on an 88. You could always just probe the wire and see which one is 12v hot.
Old Jan 18, 2009 | 05:48 PM
Ca[maro]88's Avatar
lost my tool that did that. when you touch it it lit up, yeah its gone. thats why i ask, caus ewhile i was touchin wires together, nothing was working. idk. ill prolly look at it more tomorrow. but what is the gray wire? its in the same harness as the yellow and black.
Old Jan 18, 2009 | 05:49 PM
Car: 1991 Trans Am
Axle/Gears: Stock
so i should hook it up to the yellow and orange right??
Old Jan 19, 2009 | 01:58 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
gray is a speaker wire color usually
i havent hooked up the radio in my car yet. i also have no factory harness. some dumbass before me cut it.
if i remember correctly though, black-ground, yellow-ignition, orange-constant
check it out man. hope that helps!
Old Jan 19, 2009 | 11:30 AM
Ca[maro]88's Avatar
thanks everyone, ill see if this helps!
Old Jan 19, 2009 | 12:29 PM
AKATDOG's Avatar
Car: 84 Z28
go to the dollar store and buy a test light, it will save u time and money for fuses and a new deck if hooked up wrong
Old Jan 19, 2009 | 01:04 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
quick side poll: Did anyone else installing a pioneer deck have issues getting it to fit? Mine wouldnt push in far enough to the bracket to lock in i pulled it out and saw 2 little black humps on the sides that the 2 corners were hitting, i dont know what they did but theyre gone now lol Anyone else have to do that?
Old Jan 19, 2009 | 02:21 PM
Ca[maro]88's Avatar
mine was JUST like that. those 2 little black humps were in the way, they're for a little vent thats next to your leg when you sit in your seat. i dont have a heater or A/C cause they dont work. i dont plan on having a heater or anyting anyway so i took a hammer and broke it out (i couldnt get anything in there to cut it without pullin the center counsel out.) so yep i broke it out and took that metal plate that held in the stock radio and it all fit good.
Old Jan 19, 2009 | 08:32 PM
Al Hasse's Avatar
You could also use a heat gun to soften the heater ducts and form them to where your deck will fit. I've also seen this done to the defrost ducting in the dash to make a larger than stock speaker fit. This also maintains the functionality of the heater ducting.
Old Jan 19, 2009 | 08:51 PM
Car: 1991 Trans Am
Axle/Gears: Stock
damn thats my prob yellow is ignition i have it on orange and yellow lol duh thanks so much for the help
Old Jan 20, 2009 | 12:28 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
oooohhhh thaaats why my little leg vents dont blow as hard, eh oh well the deck is worth it lol i just used a drill to cut a ghetto perforation into it and pushed on it and they snapped right off
Old Apr 15, 2009 | 09:17 PM
I got a harness i just dont get how it attaches to the connectors from my camaro
like is there any pics any where or a vid?
Old Apr 16, 2009 | 02:18 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
You know you can get a haines or chiltons manual and they have the wiring diagrams and you can take both diagrams and put it together really easy. As for the unit hitting things in the compartment I had no problems except with the metal bracket and I usually take that out.
redmaroz
Apr 25, 2017 07:14 AM
mustangman65_79
Apr 14, 2017 05:37 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
zayne0
Aug 24, 2015 07:22 PM
rithsleeper
Aug 11, 2015 07:55 AM
