2 10" in the rear quarter
Old Jan 21, 2009 | 04:42 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i out my to 10" subs in the pass side rear quarter panel. Its Custom the sit real nice and i put insulation all around in the panels i cant wait to get my car on the road again to hear it. I did it this way so i have a spot for my t-tops when i take them off instead of letting them slide around lol heres some pics lmk what all you guys think. (ALSO THE PANEL FITS BACK ON WITH NO PROB)
Old Jan 22, 2009 | 01:35 AM
ILUVMY89's Avatar
Re: 2 10" in the rear quarter
Attachment 170253
Attachment 170254
that looks shitty and ghetto imo
Old Jan 22, 2009 | 09:36 AM
Car: 1991 Trans Am
Axle/Gears: Stock
well i just put insulation around it lol idc man i dont feel like having another system robbed out of my car and also then i have a spot for my t-tops lol but then again you can tell what it looks like with quarter panel over it
p.s. i know what you mean but lm keeping it
IMO if thats your camaro i feel really bad for you. who puts like 22" rims and lambo doors on a camaro and you probebly got a shity speaker system also
Old Jan 22, 2009 | 05:53 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
dont bash him when you asked for an opinion. and yes it does look ghetto do it right or take out the subs
Old Jan 22, 2009 | 06:31 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
IMO that looks terrible and looks like it would sound terrible, plus you run the risk of overheating them but having them enclosed in the insulation and have the panel over them. Do a search and learn how to make an enclosure with spots for your t-tops.
Old Jan 22, 2009 | 06:56 PM
1LOMARO's Avatar
Car: 89 Camaro, 94 z-71,98 Camaro
Engine: none, 350 tbi.sixxer
Transmission: none, 4l60e,auto
Axle/Gears: none, 3.73
Easy fella's.... but I do agree that there is a better way than that. But its your dollar and your ride so.....
Old Jan 22, 2009 | 07:34 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
My only concern is that putting the panel back on you may have some rattling and maybe drowning of the subs, but it is your car so watever.
Old Jan 22, 2009 | 07:43 PM
Car: 1991 Trans Am
Axle/Gears: Stock
well w/e i had a 8 inch back there and it sounded great imo but its cool w/e i know what im doing when it comes to subs
i do what i can so...
Last edited by blkfirebird91; Jan 22, 2009 at 07:45 PM. Reason: Automerged Doublepost
Old Jan 22, 2009 | 07:46 PM
DanTeix's Avatar
Engine: 305 TBI
Does the insulation help with rattling or something Ive had the same kind of idea.
Old Jan 22, 2009 | 07:55 PM
Car: 1991 Trans Am
Axle/Gears: Stock
yeah it makes it rattle less its not behind the sub its just around them so they dont rattle. they fit fine so it wont catch on fire because its not on them its just around them.
you get more bass sound from it then rattle like s**t
Last edited by blkfirebird91; Jan 22, 2009 at 07:56 PM. Reason: Automerged Doublepost
Old Jan 23, 2009 | 01:00 AM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
they should be just fine. They wont catch on fire thats for d@mn sure. If your running any more than a 300 watt amp just make sure its well vented. No foam around it.
Old Jan 23, 2009 | 01:28 AM
ILUVMY89's Avatar
OK FIRST ALL YOU HAVE NO ROOM TO TALK ABOUT SHITTY SYSTEMS I MEAN LOOK AT YOURS HAHAHAH AND AS FAR AS THE LAMBO DOORS AND MY 22'S THAT LOOKS TIGHT AS HELL ESPECIALLY WITH MY 5 INCH PIPES AND FOR YOUR INFO I HAVE KICKER 1 INCH TWEETERS, KICKER MIDS, 2 KICKER COMF 15'S, AND A 4000 WATT LANZAR AMP AND IF YOU DONT LIKE WAT PEOPLE ARE GONNA SAY ABOUT YOUR SHITTY *** SUBS AND GHETTO *** RIG YOU GOT THERE CAUSE ITS DAMN SURE NOT ANYTHING ELSE DONT ASK PEOPLE FOR THERE OPINION
Old Jan 23, 2009 | 02:46 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
apparently
Old Jan 23, 2009 | 09:08 AM
Axle/Gears: stock
I've been around car audio all my life. My dad was a professional installer for years and did many competetions. I've done 2 third gens with him and hes done another 2 by himself. one of the two we did together was in the panel like that. We used to fans built into the panel to help keep air circulating and used alot of sound deadener to keep it from rattling. He built a custom fiberglass box to fit in there (i had no idea how to do fiberglass then). But it was an awesome install and looked beautiful.. We also did 2 10s but there were Rockford hx2s powered off an Rockford power 1000 with a built in fan. It didn't overheat and sounded amazing. But that insulation is very suceptible to heat even around the subs. I'd just be careful and if the amp is in there also, i'd move it, in that small of an area that vibrations from the subs can cause it to damage the board inside. We had the amp mounted in the locking box on the rear driver side. Just a tip.
Old Jan 23, 2009 | 09:12 AM
Car: 1991 Trans Am
Axle/Gears: Stock
ok cool thanks for the info but i took my back seats out an i have the amp sitting nicely where the bottom seat cushion used to be and its an 800 watt amp so i think it should be fine.
lmfao you on your rag or something??? btw man you car looks like s**t with those rims and doors.
Originally Posted by champnesupernva
apparently
yeah im not made of money like some of you guys on here...
Last edited by blkfirebird91; Jan 23, 2009 at 09:14 AM. Reason: Automerged Doublepost
Old Jan 23, 2009 | 11:08 AM
Axle/Gears: stock
yeah right now im running a sealed box in my hatch with 2 rockford fosgate p2s 10".. they sound amazing and hit hard in the hatch. But im gonna redo it all with 2 12's ported or 1 15 ported.. but i got other stuff to do b4 i waste the money on audio..
Old Jan 23, 2009 | 02:52 PM
ILUVMY89's Avatar
i think its funny that your still trying to talk shi.t just face it your **** is wack ugly ghetto shitty watever you wanna call it thats wat it is i guess you cant spend 60 bucks fora box you must be really poor but look at your setup so i wouldnt doubt it and dont be talking about my car i didnt ask you how does my car look i could give a **** less wat you think
Old Jan 23, 2009 | 03:06 PM
Car: 1991 Trans Am
Axle/Gears: Stock
stfu you homo why dont you sell that wanabe lambo and buy a real one
Old Jan 23, 2009 | 03:10 PM
DanTeix's Avatar
Engine: 305 TBI
The Mods should eliminate all you who flame way to f*cking much i mean seriously back and forth. Its funny like every opinion thread ends up this way.
lmao
Old Jan 23, 2009 | 03:11 PM
Car: 1991 Trans Am
Axle/Gears: Stock
yeah hes a dumb bitch at least i pay for my **** and not have it handed to me..
Old Jan 23, 2009 | 09:18 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Did you pay for those hood pins?
Old Jan 23, 2009 | 09:19 PM
Car: 1991 Trans Am
Axle/Gears: Stock
yeah i did... are you being sarcastic or you serious about it???
Old Jan 23, 2009 | 09:32 PM
Just poking fun at the whole situation. You asked for opinions and then got bent out of shape when they were offered. IMO I like the idea of a sub down in that spot, but it does look a bit "ghetto" for lack of a better word. If it was cleaned up a bit I'm sure it would actually look nice. To show I'm not just picking on you, I don't care for 22" rims on 3rd gens either but he took the time to make it look nice to him and others who do. The other guy didn't ask for opinions so I won't bash him. Basically my point is to take the critiques from people and improve on your original design. Effort is far more valuable than any amount of money anyone can throw at a car.
Old Jan 23, 2009 | 09:38 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
okay im not in the middle of this at all but i got like 2 things to say really quick. your subs look like crap sitting next to insulation HOWEVER, they wont get stolen and im sure they sound good. iluvmy89, i think your mistaken a CAMARO for a CADILLAC. camaros should not run 22's.. its embarrasing to our world.. and the lambo doors.. they look... eh. this isnt an rx7 or an s13 or 3000z. its a camaro. its our modern day muscle. not a ghetto p.o.s
Old Jan 23, 2009 | 10:34 PM
Car: 1991 Trans Am
Axle/Gears: Stock
ill take your advice and ill try and clean it up alittle more make better presentable but i want to keep the insulation so you can hear the bass not rattle so blacksunshine do you have any suggestions i should do to make it look better and keep the insulation ?
Old Jan 23, 2009 | 11:33 PM
Ca[maro]88's Avatar
put some plywood pieces over the insulation or something. maybe just paint it black or something lol
Old Jan 23, 2009 | 11:49 PM
Axle/Gears: stock
DYNAMAT EXTREME FTW!!! or just a decent amount of peel n seal from ur local menards or lowes and home depot
Old Jan 24, 2009 | 03:48 AM
ILUVMY89's Avatar
handed to me i paid cash for all my shi.t im gonna drop this cuz ur prolly a hillbilly judging by your car and install.. and for whoever said camaros arent supposed to run 22's who gives you the right to say anything it aint ur car so mind ur own... i do wat i want to MY CAR i dont care wat people think wat is or isnt supposed to look good in their opinion it ABOUT MY OPINION and blkfirebird should quit with his LAME *** COMEBACKS AND JUST STFU CUZ HIS **** IS GHETTO AND SHITTY AND FACE THE FACTS DONT LIKE MY RESPONCE DONT ASK FOR OPINIONS END OF TOPIC
Old Jan 24, 2009 | 10:54 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
You sure you shouldn't be driving a Cadillac? These are Muscle cars, you should be ashamed of yourself, Ruining a good car for stupid mods. It doesn't look ''TIGHT AS HELL", but rather incredibley stupid. And don't type in all caps, it just completes the look.
Old Jan 24, 2009 | 11:20 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Everyone has to start somewhere. My first "system" was put together with Pyramid $hit I bought at a pawn shop and put together with lamp cord and wire nuts...that was nearly 20 years ago.
The question is whether you progress.
Nice inventiveness. Needs better execution. Keep at it.
Old Jan 24, 2009 | 12:05 PM
blkfirebird91,
use something to cover the foam. If you're on a tight budget, try using some 3/4" particle board. You can get a huge sheet at HomeDepot for around $20. Cut it to fit the area and mount the speakers to it that way you'd have a much cleaner appearance. Nobody will care what's underneath. While you're at HomeDepot, pick up some of that peel n' seal to help with your rattles. Does that make sense or help?
ILUVMY89,
Have you every heard of the phrase "clean up your own backyard first"? When you begin to criticize him in the manner you did, and then did again, and again, you open the door to be criticized yourself. 22" rims are to big for 3rd gens. They are not proportional to the rest of the car. But its your car and as long as you're happy then that's fine. But one word of advice, "punctuation"-use it! One gigantic run-on sentence of misspelled words makes you appear illiterate.
Old Jan 24, 2009 | 03:50 PM
Car: 1991 Trans Am
Axle/Gears: Stock
ok blacksunshine91 thanks for the advice ill goto home depot tomorrow and pick some up. also by foam you are meaning the insuulation right? so you dont see the insulation anymore?
ill try and do better lol thanks for the comment.
Last edited by blkfirebird91; Jan 24, 2009 at 03:51 PM. Reason: Automerged Doublepost
Old Jan 24, 2009 | 05:46 PM
Ca[maro]88's Avatar
bradley25150 you see what im talkin bout with the cadillac thing? lol. alright well im out with this thread but BLKFIREBIRD91 after you fix your subs and make them look right send us a pic so we can tell you "good job"
Old Jan 24, 2009 | 08:05 PM
Car: 1991 Trans Am
Axle/Gears: Stock
ok i will lol im pretty much done here also
Old Jan 30, 2009 | 10:49 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
not to ad more fire to the fight but that **** is ugly just get a box bro. dont blast your **** in the hood and you should be ok lol
Old Jan 31, 2009 | 01:25 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Just do this.......
https://www.thirdgen.org/forums/car-...-sub-sail.html
Old Jan 31, 2009 | 02:12 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
Dude why would you do that to a third gen 22s what the hell. Looks like you could enter a monster truck compatition. As for the subs in the insulation if thats what you can afford then make the best of it. As for the monster truck with lambo doors i wouldnt say much.
Old Feb 4, 2009 | 12:41 AM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
**** heads like to give some bs as posts like iluvmy89 and a couple others, they just open their mouths and let em flap.
Notice some people came through with good well put together posts advising the OP with their opinions. He took them well like most people take good criticism.
Good brainstorm, think up some better ways to make your idea more professional and your set, THOUGH no one is going to SEE the "ghetto" job you did any way and since it doesnt rattle and wont catch fire it really doesnt matter now does it?
But those 22's lambo doors and ugly hood macco paint job people will see coming a mile away and even dudes in the hood will laugh, true g's know you pimp a caddy like that and have the camaro as the sleep to take peoples money but I guess your just not a true g now are you?
Rockjay your advice is very true yet had me crackin up thinking about driving through east orange at 8pm in my camaro BLARING my subs at a stop light...the whole hood was looking at my *** like wtf is he doin here!
Old Feb 4, 2009 | 12:55 AM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
let it die already... also, the armpit of america has a hood? please stop with the e-thug bs
Old Feb 4, 2009 | 01:10 AM
jersyboyy's Avatar
Car: 85 Camaro
Any ethug bs from my mouth was sarcasm...thats a commen thing in this area...the armpit...have you ever been to jersey?
Most people know the mainstream slander for this great state but have NO idea the beauty our country has hidden in this state.
Most of the top celebrities bands athletes are rom new jersey, not to mention our beautiful beaches the beautiful people some of the MOST exspensive towns with the nicest homes youve ever seen, the history that this state has is incredible, the museums the historical sites,colleges not to mention the farms, theirs a reason where the garden state.
Oh yea and the hood we got them too and east orange was once one of the top 10 worst cities in america(we got some top 10 best areas too) I could go on for hours bro just say the word.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
overdriv
Aug 20, 2015 03:52 PM
BlackTopKing
Aug 19, 2015 12:13 PM
Exxon Limited
Aug 9, 2015 08:13 PM
