Capacitor before speakers?
Old Feb 17, 2009 | 04:53 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
I just replaced my front speakers. These were 10W nom 20W max, I put some 20W Nom 130W max. There was something like a capacitor (I did not remove the plastic yet) on one wire of each one. What is it for? Reduce power? Phase correction?
Anyway I removed them, it is working fine. The audio is a two years old mp3 player 4X50W. Can someone explain me?
Old Feb 17, 2009 | 05:07 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Capacitor before speakers?
Was it touching both wires to the speaker? or were both contacts on one wire.
Old Feb 17, 2009 | 06:31 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Hi,
If you are having trouble with the front speakers over-driving with bass settings, then you would install the capacitor in series with one of the leads- not across the speaker leads.
take a look at this link:
http://www.bcae1.com/capspkr.htm
Old Feb 17, 2009 | 07:19 PM
loopingz's Avatar
Thanks you are right on the point. The capacitors were "in serie" (just on one wire).
My electrical classes were not so fresh... but now I remember, it creates high pass filter really useful if you have a boomer installed (which was previously the case in my car). Now I need to look at the rear ones to remove it too.
Old Feb 17, 2009 | 10:42 PM
ntomsheck's Avatar
Car: 1989 GTA
Yeah I was gonna say, if it's all on the same wire, it's a filter like you stated. If it were across both wires, I would have said AC/DC noise suppression.
Old Feb 22, 2009 | 03:17 AM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
ya almost defently a filter for low pass or high pass frequency's
Old Feb 23, 2009 | 07:38 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Capacitors block low frequencies. Coils block high frequencies. Neither one do a very efficient job.
Elephantismo
Feb 13, 2019 12:51 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
codeysabatini
Sep 20, 2015 11:36 AM
