My first attempt at Kick Panels
Old Mar 18, 2009 | 05:01 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
This is from the start to the pre-vinyl stage.
Attached Thumbnails My first attempt at Kick Panels-imgp1160.jpg   My first attempt at Kick Panels-imgp1161.jpg   My first attempt at Kick Panels-imgp1162.jpg
Old Mar 18, 2009 | 05:04 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: My first attempt at Kick Panels
some more
Attached Thumbnails My first attempt at Kick Panels-imgp1163.jpg   My first attempt at Kick Panels-imgp1164.jpg   My first attempt at Kick Panels-imgp1165.jpg
Old Mar 18, 2009 | 05:06 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Attached Thumbnails My first attempt at Kick Panels-imgp1166.jpg   My first attempt at Kick Panels-imgp1167.jpg   My first attempt at Kick Panels-imgp1168.jpg
Old Mar 18, 2009 | 05:09 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
.....and finaly
Attached Thumbnails My first attempt at Kick Panels-imgp1169.jpg   My first attempt at Kick Panels-imgp1174.jpg   My first attempt at Kick Panels-imgp1175.jpg
Old Mar 18, 2009 | 05:30 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
That is very cool. Do you have a list of materials and step by step instructions on how you're doing this? If not, how much would you charge to make them? Bare would be fine.
Old Mar 18, 2009 | 06:02 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks for the compliment. To make them, and make them worth while would be to much. It's quite a bit of work. Not really to hard, all though it is somewhat trying. All I did was:
Rip out the kicks and pull the carpet off. Grabbed some cardboard and traced out what would be 5 1/4 components, then made sure they baffle would be as small as practical would allow. I then made the baffle out of 3/4 MDF and routed the sides with a round over bit. The 5 1/4 hole is cut out to flush mount the grill with some room on the sides for the vinyl to tuck in. I then made some standoffs with a dowel in order to hold the baffle off the kick panel. Getting the fiberglass to adhere to the plastic is a bit of a bastard. I made the mistake of cutting the shirt to short. I should have brought it around about 6'' on all sides and glued it more towards the middle of the backside of the kick panel. The resin reactivates the spray glue and loosens the shirt. Now I know what to do for the drivers kick anyway. To compensate for my mistake I covered the whole back with fiberglas sheet and wrapped it around the to the front side in order to lock everything onto the plastic kick panel. it seems to have worked out. Before that I resined the shirt by itself and let that dry. After that I wrapped 2 layers of fiberglass sheet, let that dry then body filled it. Sanding is a lot of fun. Anyway I'm now ready for vinyl.
Old Mar 18, 2009 | 06:40 PM
strc09's Avatar
Interesting. I've never worked with fiberglass or anything like that before. Very cool though and two thumbs up.
Old Mar 18, 2009 | 06:50 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
It's really not that bad. Messy as hell. It cost me about $70.00 in supplies, thats for a 1/4 sheet of MDF, 1/2 gallon of resin, 3 tubes of hardener, 3 packs of $1.00 brushes, sandpaper, body filler, 8 cubic feet of fiberglass, and plastic cups. Give it a shot. Try covering a block of wood to get the hang of it. Feel free to PM me if you have any questions. Took me about 10 hours to make it, I imagine I'll be quicker on the next one.
Old Mar 18, 2009 | 07:28 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
That is just for one? Other then that nice job, looks pretty sweet.
Old Mar 18, 2009 | 08:34 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
No it's for both with plenty left over. Just have not started the drivers side yet
Old Mar 28, 2009 | 05:33 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
This is the final product, just put the vinyl on this afternoon. It's a bastard to do, in hind sight I would have spent more time finishing the bondo and coat it with ruberized rocker guard then a cover coat of tan paint. Anyway it came out pretty good, the drivers side is not quite as nice due to more complex angles making the damn vinyl a total goat show to wrap.
Old Mar 28, 2009 | 08:14 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Dude, that its pretty sweet. Did you consider angling it towards yourself? Then again....might stick out more and be in the way. Anyway like to know how they sound.
Old Mar 28, 2009 | 08:34 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Looks pretty good!
For future reference you could actually apply a texture over the finished surface and the then color them with sem color coat to match your interior if you didn't want to mess with vinyl.
http://www.yourautotrim.com/semteco.html
Or use a omni stretch vinyl, it's really thing and can pull to stretch over the toughest angles. I use the white vinyl and then apply a color coat to match the interior.
http://www.yourautotrim.com/al4stvi.html
Old Mar 28, 2009 | 09:15 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Textbook execution dude. Nice job.
Old Mar 29, 2009 | 05:53 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks for the Kudos. As far as the angle, I was trying to find the best of both worlds in trying to get good sound quality and not interfere with leg room. The drivers is on more of an angle due to the hood release. Not dure how they sound yet.
Old Mar 30, 2009 | 10:34 AM
1Aauto's Avatar
Former Sponsor
Those came out real nice.I always liked the small custom interior stuff.
meeklay812
Oct 1, 2015 03:46 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
formula00ra
Sep 28, 2015 11:50 AM
tattmann
Sep 27, 2015 05:20 PM
