2 MTX 12's
Old Apr 14, 2009 | 09:47 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
2 MTX 12's
i have a kenwood head unit, kenwood 350w amp and 2 12 inch mtx subs. but if i get above volume of 25ot of 39. my subs like to cut out on bassy songs. does anyone know why this would happen. i am thinkin it my be my amp, is to small to power my subs. also not sure wut my subs wyttage or amps it has, idk much about my system havent had time to do so. heres a photo of them. please them know cuz i hate when they cut out. it makes my system sound dumb and embarrasing dont wrry im gettign a box made for them, there not actually goign to stay like that.
thank you
Old Apr 14, 2009 | 10:15 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: 2 MTX 12's
400 was barely enough for my 10's lol
Old Apr 15, 2009 | 06:12 AM
Re: 2 MTX 12's
so i should go get like a 850w amp or so.
Old Apr 15, 2009 | 07:57 AM
blackroc68's Avatar
Re: 2 MTX 12's
Those subs cant handle the wattage get some alpine type r!
Old Apr 15, 2009 | 03:41 PM
87350IROC's Avatar
Car: 87' IROC
Re: 2 MTX 12's
I would say you are overloading your amp. Please provide the model number of the subs and amp. Also do you have the subs wired in parallel or series?
I would bet you have the subs wired for less ohms than the amp is stable at. So when you try to crank it up, the amp shuts itself down.
Old Apr 15, 2009 | 04:25 PM
Re: 2 MTX 12's
i think im just going to get better subs and an amp.
Old Apr 15, 2009 | 05:31 PM
87350IROC's Avatar
Car: 87' IROC
Re: 2 MTX 12's
That may or may not fix the problem. I'd look into it more before you dump a bunch more money. It would also help so you don't run into the same problem with your new stuff.
Old Apr 15, 2009 | 07:05 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: 2 MTX 12's
their is a few things i would check for this problem\
First off ? do the subs just not play as loud when turned up or do they totaly quit playing?
if they totaly quit playing i would check how hot your amp is when they cut out (if the amp is to hot to touch) = BAD if warm and you can keep your hand on it thats a better sing
it could be ur cd player clipping as well so dont be 100% sure its the amp yet...
do u understand series vs parell? if so check out how the subs are wired in and look at the bottom of the amp it should say how low of Ohms the amp is stable to
if your ohms are to low for the amp it could be going into safty mode which would be your subs not playing at all untill the volume has gone down enough to be safely played again
To small of amp isnt a bad thing by any means unless your driving the amp into clipping. Basicly instead of a nice smothe in and out the sub makes a cliped signal (square shaped signal) this to the sub is like hitting a wall!
Old Apr 15, 2009 | 08:36 PM
Re: 2 MTX 12's
ok cool. thanks for the info, when i get some time over the nice weekend i can check it out. the thing is, when they were in my freidns lumina he said they worked fine.
Old Apr 21, 2009 | 04:10 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Re: 2 MTX 12's
My Firebird had this problem the amp was not powerful enough for my 12's So bought me a 1000watt and gave my wife the 500w and now it does this in her car pushing her 450w 12. Hers cuts out at about 25/32. More powerful amp should work have any friends with stronger amps?
Dan
Old Apr 21, 2009 | 08:45 PM
Re: 2 MTX 12's
yeah i got my friends 600w mtx audio road thunder RTP251D amplifier. solved the problem of it cutting out. now it can go above 30 with out it doing so. also it doesnt sound to good after 27 or so.
Old Apr 22, 2009 | 10:33 AM
DanTeix's Avatar
Engine: 305 TBI
Re: 2 MTX 12's
You might want to mess with the headunit equalizer and turn the lows down My system has them low so I can turn my radio up with out the speakers getting distorted or just get better speakers.
Dan
Old Apr 22, 2009 | 03:42 PM
Re: 2 MTX 12's
i got a kenwood head unit, dont know wut kind though. also i have pioneers in the sail panels, and stock in the dash. when i get a new dash pad, i am going to replace them as well.
tmellott89
Oct 14, 2015 02:06 PM
88_TAOD
Car Audio
Mar 6, 2001 08:46 AM
Black_Widdow
Car Audio
Jan 18, 2001 09:24 PM
PullmeoverRed
Car Audio
Dec 3, 2000 03:36 PM
