94 Camaro constant hot wire to radio
Old May 27, 2009 | 08:47 AM
dvers's Avatar
First, I'd like to thank JT for helping me with the computer problem I had with posting on this forum. I'm by no means a computer whiz.
Now my problem with the Camaro: The radio stopped working. I've checked the fuses on the drivers side dash, the fuses under the hood and the fusible links next to the battery. All were found to be good. I pulled the radio and found that the 12v to the (Orange) constant hot wire to the radio is dead. I do have 12v to the (yellow) wire when the ignition is in the on position. My questions are; Where does the (Orange) constant hot wire get its power from under the dash? Is there a fuse, relay or circuit breaker that I've missed somewhere? Also, I've noticed that the interior lights no longer work. Is this possibly related to the radio problem? Any help that the members can give me would be appreciated.
Thanks in advance, dvers
Old Jun 2, 2009 | 05:11 PM
dvers's Avatar
Re: 94 Camaro constant hot wire to radio
I guess no one on this forum is knowledgeable on the wiring issue I've got, thanks anyway guys and gals.
Old Jun 2, 2009 | 05:45 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
i found this pinout for you,
The best thing you can do is chase it down and see where it goes :/
Did you test the wire with a meter?
Old Jun 2, 2009 | 07:27 PM
dvers's Avatar
Just a 12v test light, and it's dead, ignition on or off. Think I'll try a continuity tester next. I just thought that maybe someone might have had this same problem with that wire on their Camaro.
Old Jun 2, 2009 | 07:35 PM
dvers's Avatar
rough, don't know if you got that reply about the orange wire being the illumination wire but here it is again:
The only way that the radio plays is if I apply 12v to the wire to the radio where the orange wire would have gone.
Old Jun 2, 2009 | 08:08 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
I know, thats why I edited and removed it, was thinking of my eclipse :/ then i looked it up and i was wrong on the color. sry ^.^
Old Jun 3, 2009 | 04:31 PM
dvers's Avatar
Thanks for the info anyway rough.
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
Caspar
Jun 19, 2016 11:19 PM
ZsTransAm
Aug 11, 2015 07:30 PM
