Power wire?
Old Jun 23, 2009 | 08:25 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
Power wire?
Does anybody know how many feet of power wire is needed to reach from the battery to behinde the back seat?
Old Jul 29, 2009 | 10:12 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: Power wire?
On mine IIRC, I used a 17 foot wire from battery to trunk well. And had about a foot extra. To be safe I'd go 18-20 and just cut it after you run it to your desired location.
Old Jul 29, 2009 | 10:15 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Re: Power wire?
+1
Just bought my power wire today.
and i just got my subs too... :P
Old Jul 30, 2009 | 03:39 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Power wire?
I always ended up using the pre-packaged kits and while they range between 17-20 feet, I always had more than enough to get the job done. What are you looking to put in for amplifiers and what guage are you going to be running?
Old Aug 10, 2009 | 02:56 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Power wire?
Make sure the wire is big enough to supply the juice your amp will need. You should look at MINIMUM 4ga.....but bigger IS better.
..also make sure to do the BIG 3 upgrade.
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
