Weird Radio Problem
Old Jul 9, 2009 | 01:31 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Weird Radio Problem
I just got my 88 iroc. It has a power antenna. My problem is that sometimes it will only get 1 station and other times it will get all of them. It tends to loose the stations after i have driven it "spiritly." this is making me think something is loose. Where should i start to check, and has anyone had a similar problem?
Old Jul 9, 2009 | 03:18 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Weird Radio Problem
I would check the back of the radio where the antenna plugs in first; may be a loose or corroded connection. Wouldn't hurt to pull the passenger side kick panel to make sure all mounting screws and connectors are secure on the antenna motor/base while you're at it.
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
CORV3TT3
Aug 23, 2015 11:26 AM
