Subwoofer stoped working!
Old Jul 19, 2009 | 01:22 AM
Tangent's Avatar
Hi, I know nothing about sound systems, my car just came with one. It was cool, but AAA did a battery change and now my subwoofer doesn't work. It may or may not be because of the battery change, because the sound system was not used for a week after the change.
I know it is a sony X plode woofer, with two speakers. the tweaters i think are the standard speakers. The sound is all tiny and only comes out of the other speakers. I took out the subwoofer and checked the wires, they are all attached. I cant even find the fuse box (is it under where the pedals are?) any ideas on things to check would be appriciated, this speaker setup was amazing until it stopped.
thanks!
Old Jul 19, 2009 | 04:38 AM
OneFast91Vert's Avatar
Car: 91 Camaro RS Vert
Engine: 305 TBI
Re: Subwoofer stoped working!
When the battery was changed, the person probably forgot to hookup the power wire to the positve battery terminal. Pop the hood and see if there is a red wire running to the battery.
Old Jul 19, 2009 | 07:12 AM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
^^What he said....If it is connected check the main fuse on the line to the amps...sometimes the fuse will pop when they fiddle around with trying to connect it
Old Jul 19, 2009 | 08:45 PM
Tangent's Avatar
Okay, i'll look at that, thanks
Old Jul 29, 2009 | 10:08 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
You know my 12 JL just did that to me.. Except I messed with the wires and now my bass SUUUCKS but it has good sound quality. wtf?
Old Jul 29, 2009 | 10:33 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
yeaa what everyone said check to make sure the power wire is goin into the battery its a fat wire usually red if not check the ground to the amp and also the giant fuses on the amp check them!
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
