power antenna stuck
Old Sep 3, 2009 | 07:29 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
power antenna stuck
hey guys, my power antenna is stuck in the up position, and i know the motor works, just the little plastic cord inside is broken, is there any way with out cutting it to get it out of the fender?? i tried once and i get the motor off the bracket but because its stuck in the up position i can't get it out. i don't listen to the radio in the car and even just getting it in the down position would be good, i have tried forcing it in but not so much that it would bend it. any tips?
thx
Old Sep 8, 2009 | 01:13 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: power antenna stuck
thx
THere is a repair kit you can get to fix this, I was given the location to buy it because I still need to, runs about $45.00 or so for the kit and takes 2 hours or so to do the repair.
Old Sep 18, 2009 | 06:15 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
My antenna is stuck up now too but the motor isn't running so I think I need a whole unit. In the meantime for you, I'd disconnect the harness from the antenna or pull the fuse after driving if the antenna motor is running endlessly so it doesn't drain the battery overnight (I've been there too)
*Update*
I tried like hell to remove the entire antenna assembly with the mast up but couldn't do it. I wound up cutting the mast and pulling the unit out. Now the search for a used unit or good fitting universal replacement because I see new originals for $200 and that's insane.
Old Apr 26, 2021 | 08:24 PM
Kalum MacKay's Avatar
Car: Red, 1984 Z28 Camaro, T-Top.
Engine: 5.0: Engine 305
Just in case anyone has thought about cutting the power antenna on a 3rd gen F-Body to remove it when it's stuck in the up position. THERE IS ANOTHER WAY!!
Don't cut the antenna as replacements can cost hundreds of dollars and modifications are almost always required . Instead, here is a step-by-step approach to removing your stuck power antenna.
STEPS
1.) Remove the wheel well plastic housing and rotate the tires to provide lots of clearance.
2.) Remove the brackets holding the antenna in place by removing a few screws. You will have to rotate the motor mechanism to access the remaining two screws once you take off the first bracket screw. REMOVE ALL BRACKET SCREWS including the bracket itself and then remove the black antenna wire by removing two small screws.
3.) There are 3 wires attached to the power antenna. You may find another method; however, I just cut them.
4.) Pull theantenna mechanical unit connected to the aerial towards the wheel well while lightly pushing down on the antenna until the unit pops out from behind the fender. NOTE: The aerial may bend slightly as a result of significant forces exerted on it to pull it through the top and structure of the fender.
5.) Once the top of the aerial clears the fender top hole and substructure, pull it out through the wheel well until the entire unit is removed.
Spd-Kilz
Car Audio
Aug 31, 2013 10:41 AM
cruise83
Car Audio
Feb 22, 2011 04:14 AM
80schild
Jun 25, 2009 11:15 PM
mbrownone
May 6, 2007 07:47 PM
GTATransAM
Aug 6, 2002 10:47 PM
