Any One Make A Sub Box Like This?
Old Oct 15, 2009 | 11:59 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi Guys,
First off let me say I'm not looking for some crazy awesome bass. But more that the factory stuff. What I want to do is make a sub box in the trunk well that is flush with the rest of the floor. So that it's not obvious I have subs, (i'm really looking to hide everything). Could I get away with this with say, an or 8" or maybe 10" sub (a pair)? Was looking at the kicker refurb subs, but not sure if there is enough airspace. And also for two subs will a two channel amp be enough.
Thanks Guys
Alex
Old Oct 15, 2009 | 12:12 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: Any One Make A Sub Box Like This?
There are alot of technicalities to that so there is no straight up answer....
As for the box. No. No one sells one that you are looking for aftermarket. There are aftermarket ones that you can buy(not the style you want) but arnt worth the money at all. Do a search and im sure you will get about 4000 hits on it. There have been plenty of sub box plans, pictures, and talks on here. Just about every week someone asks about "will this work". So just take a look back a few pages or just do a search it will show you alot.
My .02 cents is to build yourself a box to your liking out of 3/4 mdf board. Thats what I did. Here is a picture of my set up. Not what your looking to do, but a good example of what you can do...
Old Oct 15, 2009 | 02:16 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Originally Posted by novafirebirdguy
Hi Guys,
Thanks Guys
Alex
As far as cone space goes...two 8" are the same as 1.25 10" sub. Two 10" is the same as having 3.2 8" subs. I'd go with the 10"s. You can always turn down the gains on the amp.
As for the amp...it depends. Most people go with a single channel (mono) amp. If the woofers are 4 ohm then make sure the amp is 2 ohm stable (for the load).
Two 10" should have enough space in the hatch area.
Check out this thread for a flat sub box.
https://www.thirdgen.org/forums/car-...amp-build.html
You could go with a single 10" (DVC - dual voice coil) sub and mount it in the bottom of the trunk (flush with the ledges). It would look like you don't have a sub and still give you a bit of a trunk area.
Old Oct 15, 2009 | 11:24 PM
Thanks for the help guys, and thanks for not being an a$$ about not searching, I know better. The link is exactly what I want to do, just with two subs. I think I know which amp and subs I wanna use.
Would this amp: http://www.hifisoundconnection.com/S..._by/sell_price
And these subs: http://www.hifisoundconnection.com/S..._by/sell_price
Be a good combo? Thanks again guys!
Old Oct 15, 2009 | 11:44 PM
Car: 89 IROC
Yup they'll work. The amp can be used in 2 channel (112.5w each) or bridged to gvie 550w total to the two. Go for bridged.
Make sure you get a copy of the warrenty for the subs as they are re-furbed.
Old Oct 16, 2009 | 09:22 PM
Sweet, thanks man!
Old Oct 16, 2009 | 10:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Check my thread - maybe give you an idea:
https://www.thirdgen.org/forums/car-...mp-us-old.html
Old Oct 17, 2009 | 06:02 PM
That's exactly what I'm looking to do, playin the same tunes too. Thanks for the help yet again!!
Old Oct 17, 2009 | 06:52 PM
Car: 1992 RS
Engine: Carbed 350
One little update on my setup - the Super77 adhesive didn't hold the fabric to the grill covers, so I ordered an extra pair of grill covers and mashed the fabric between the two so that the fabric didn't flop with each hit of the bass. But I'm very happy with it - it was cheap, easy (took me about 2 hours to make), and thumps plenty for me!
Old Oct 19, 2009 | 09:20 PM
87L98GTA's Avatar
Car: 87 GTA
Engine: 350 tpi
i had a set of the same kickers i did not like them that much.to me alpine sounds better
Old Oct 19, 2009 | 09:52 PM
Thanks for the tip. I've been considering just getting one 12" better quality sub instead of two 10's. Or maybe a 12" and an 8" to get a little different sound range.
Alex
Old Oct 19, 2009 | 10:26 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
if you can get a deal on an Alpine Type X you will like it way better than the kickers, they can handle alot and will last forever (well maybe not forever but longer than the kickers will). also should try your luck with a fiberglass box.
Old Oct 19, 2009 | 10:34 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
PM me. I have a sub box maker. Called Probox. if you have vista idk if it works but giving it away free to all that are 3rd gens.
Old Oct 19, 2009 | 11:39 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
cept for the price of a type x or even r , u get into the realm of much much better subs... such as RE
Old Oct 20, 2009 | 10:28 AM
Car: 89 IROC
Alex
GO with the single 12"
Old Oct 20, 2009 | 12:23 PM
I think I'm gonna go with a decent 12" like an alpine or something similar. Might get an 8" too. Also interested in that sub box maker too. I'll send you a pm.
Thanks guys
Old Oct 25, 2009 | 07:00 AM
one92rs's Avatar
Car: SOLD!!!!!
the kickers will do fine. have used kickers for years and love them. have used alpine in the past. still like my kickers. have used the crunch amps as well. and still using them today. also i like the autotek amps more than i do any other one.
Old Nov 1, 2009 | 09:08 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
You can't do a 12 and an 8, by doing so you'll get alot of sound cancellation. Always run the same size woofer, never mix and match.
Old Nov 2, 2009 | 07:02 AM
Thanks! Will do.
Old Nov 10, 2009 | 03:52 PM
redtruck18's Avatar
Car: 1987 RS Camaro
Engine: 305 V8 (Carb)
Huge thanks to berlin305 for the software.
Old Nov 10, 2009 | 08:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
My Polk 10" only required a o.5 cu/ft box sealed so I stuffed it down in the well and made a crappy cover to hide it. The pad on top of the box was to just add to the height of the box since it didn' sit flush with the side ledges. It certainly won't shake the car apart or **** off someone 3 blocks away but, it does enhance the music... like adding a sub to your home stereo. It's not there to kill your ears or impress anyone... just enhance the music you're already enjoying in your personal space.
Attached Thumbnails Any One Make A Sub Box Like This?-dcp_0014.jpg   Any One Make A Sub Box Like This?-dcp_0013.jpg
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
BikeFarm
Aug 11, 2015 11:35 PM
bryan623
Aug 10, 2015 11:33 AM
