Monsoon cd radio
Old Oct 31, 2009 | 11:31 PM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Monsoon cd radio
I got a monsoon cd player from the local bone yard real cheap and it plugged right up but the cd player will not play when i put a cd in it says no data. I know it could be broken but was just wondering if there might be an adabter out ther that might help since the cat came with a tape player and not a cd. thanks
Old Oct 31, 2009 | 11:54 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Re: Monsoon cd radio
I've got a 87 GTA that came with a cassette deck. I installed a 99 Grand Prix cd player in it a 1 1/2 years ago, and no problems yet. Like you said, yours could be broken!
Old Nov 2, 2009 | 07:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
The CD player should work no problem if you're using a standard CD, no adapter needed to play. Are you trying something you copied/burned or an original CD? Some of the stock decks have issues with burned discs, but you may just have a malfunctioning deck.
Old Nov 2, 2009 | 12:39 PM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
It sounds like the Laser assembly is burned out and the unit needs to be repaired. It says no data because it's not reading the information on the disc. This is usually a costly issue, running about 300 for a typical repair. I would only recommend the route for cars that have to have the monsoon head unit to power the factory amps.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
