Custom Sub Box Builds 1,2, and 3
Old Nov 29, 2009 | 02:02 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
My system is 2 x Blaupunkt 300w RMS 600w MAX 12” subs and a Pioneer 760w amp that I picked up off craigslist for dirt cheap. This is my first real experience with woofers ever.
My first ever subwoofer attempt was a free Box, but it caused too many rattles despite decent sound.
Old Nov 29, 2009 | 02:03 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Re: Custom Sub Box Builds 1,2, and 3
I then decided to go sealed. So, I measured my trunk, and figured it out as I went along. It kicked pretty hard, and I stayed with it for about 5 months. It was MDF filled with cotton stuffing for the lack of volume.
Old Nov 29, 2009 | 02:04 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Then comes the real fun. I got bored one day, and decided to teach myself fiberglass, as I had never touched it before. I picked up a few online tutorials and went at it.
Lined my trunk and laid down some fabric. Then applied generous amounts of resin:
Made a hollow shell for the bottom
cut out ¾ MDF for the top, and rings
mounted rings and test-fit subs
started clothing the top
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
First layer resined.
Cut off overhang and glassed the top to the bottom (such a pain to fit)
http://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs027.snc3/11468_185710504138_644534138_2963383_6409030_n.jpg[/IMG]
used an impact sander around the entire thing
Bondo!
Old Nov 29, 2009 | 02:05 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Bondo sanded, putty applied, sanded again, and drilled holes and mounted the mounting posts for the amp.
Done!
I can’t show what it looks like in the trunk since its too dark for a picture, but it fits perfectly snug. In total I spent close to $200 in materials including a whole bottom shell that was trashed as a learning mistake. It took a lot of weekends to finish, but I am glad it is done, and it sounds amazing. I am waiting on LED’s I ordered to mount beneath the amp to glow outwards and illuminate the box.
Old Nov 29, 2009 | 04:30 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
great job!
i never understood the purpose of stiffing a box with cotton/polyester
Old Nov 29, 2009 | 08:46 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
It slows down the waves and is used to help a box that is too small. This is what the internet told me, and it worked.
Old Nov 29, 2009 | 12:19 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
Very nice work .....
Old Nov 29, 2009 | 12:26 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
thats awesome i plan on doing that one day but i want to do a half box so its just one side of the trunk i built one outta mdf for now but fiberglass would be awesome also idk how true it is but i heard that mounting your amp to the box is bad? they said it was because of the vibrations from the sub can ruin the amp good work though
Old Dec 1, 2009 | 02:27 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Very nice work, I've never done fiberglass before, but you've made me want to try.
Eric
Old Dec 1, 2009 | 04:17 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
fiberglass looks pretty sick =]
Old Dec 12, 2009 | 02:07 PM
The Misfit's Avatar
Car: 1991 Z28
Engine: LTX
Axle/Gears: 3.43
Man I cant believe how well this thing turned out. For two idiots that haven't ever messed with fiber glass before, I say we did an amazing job Now you just got to figure out something about the amp.
Old Dec 13, 2009 | 12:08 AM
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
Looks awesome man! I built my "big" setup out of MDF and made a leather cover to go over the entire hatch area. I'd love to see how it looks in your car!
Old Dec 13, 2009 | 06:15 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Very nice job indeed
Old Dec 13, 2009 | 10:47 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
neon lighting underneath?
Old Jan 11, 2010 | 09:14 AM
1992-RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
thats awesome..plan on doing the same thing in my 92'
Old Jan 11, 2010 | 12:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Nice job on the glassing. Definitely not for the faint of heart or a quick job, but very impressive when you're done
Old Jan 31, 2010 | 04:30 PM
86IROCcloner's Avatar
Car: 1986 Chevy Camaro Sport Coupe/IROC
Engine: 4.6
Transmission: T-5 Borg-Warner
Wow.. I mean wow! that's awesome! it looks great and is fairly cheap! great job man that encourages me to do something like that. I'm considering replacing my rear seats with speakers...
Old May 11, 2010 | 02:50 AM
jsehorta's Avatar
how much does it weight with out the subs and amp?
Old May 11, 2010 | 07:05 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
From the size and MDF used I would probably say around 50 lbs.
Very nice build!
The recessed rings look great. I assume you also used tee nuts on the rings? Have you decided where you are going to drill to the run the wires inside to the subs?
Old May 12, 2010 | 11:56 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
That looks very good. Its nice seeing people who actually take the time to do a good job on something rather than just stuffing everything together because its faster.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Fast355
Dec 2, 2016 06:33 PM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
