A single 12 inch sub in you thirdgen...Whose got them?
Car: 1991 Camaro RS
Transmission: 700 R4
I'm looking to put a single 12 inch sub in my 91 rs. Does anyone have any pics or ideas for a custom made box? I'm looking for a nice clean look. Thanks
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: A single 12 inch sub in you thirdgen...Whose got them?
Put it in a detergent box,that'll give u that "clean" look
JK
you should be able to build one for just 1 sub to sit flush in the hump,
And mount the amp directly over the gas tank (without drilling trough it of course)some people add an extra piece of mdf under it to be safe)
JK
Car: '92 Camaro RS | '11 E92 335i
Engine: 305 TBI V8
Axle/Gears: Stock
depends how big you want the box and the specs on your sub and what sqft. the sub will sound best at. **** i built my own box for my 15" Solo Baric and it fits pretty well.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
No box - just a shelf with one sub - it's a 10, but a 12 will work fine, as I have my 10 covered with a 12 grill. It sounds great, no rattling issues, and plenty of thump (for me anyway), it was cheap, easy, and took under 2 hours.
see: https://www.thirdgen.org/forums/car-...mp-us-old.html
Axle/Gears: Stock
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
i made a box for my ten its just half the well and it doesnt sit fully flush the mdf pretty much rest on top
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I cut some mdf to shape the entire area under the hatch. cut out the hole for the single sub,covered with carpet, added sub and set my amp under in the well. made for a solid look. sounded awesome as well.
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i wouldnt go this route, a baffle wont sound as good as a real box, and the amp is getting excessive vibrations as well risk overheating
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Start with the plans attached. I modified them a bit to fit the cubic feet of air needed for my single 10" sub. It sits in the well and I mounted my sub, amp, and capacitor on top of it. You may need to put some rags under the leading edge of the lip as it may vibrate the hump over the fuel tank. Sounds awesome!
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Budget Build.......
Engine: 305 TBI V8
Axle/Gears: Stock
The "Bucket Sub." I know that one, it actually sounded pretty decent for what it was
He has since gone on to something else.
He has since gone on to something else. Thread
LT1Formula
Oct 8, 2015 08:34 PM
