will these speakers fit my car?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
hello guys and merry xmas
i just recieved the sony xplode bundle as a gift and im wondering
will the 6.5 speakers fit in our dash?
and will the 6x9s fit in our back?
my cars a 90 camaro RS
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: will these speakers fit my car?
6 x 9's will fit rear. think the dash is 4 x 6 - but you might do a search, I think someone converted the dash speakers to round but I don't remember what size.
Merry X-mas
Merry X-mas
Engine: L31 350
anyway i could maybe fit these speakers in there?, my passanger side speakers are blown
Car: 1984 camaro z28
Engine: 305 H.O.
Transmission: 700r4 automatic
Car: 87 T-Top GTA
To fit the 6.5 speakers, your gonna be cutting some of the plastic heat/cool duct out!
1 Post
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Or you can fab (or buy if you've got 200$) kick panel speaker mounts that would allow you to put the 6.5's down by your feet angling upward for better sound projection. They will fit in the dash with a little persuasion, chances are though you'll have a bunch of dash rattles when the bass hits, although they can be fixed pretty easy. Either way the 6.5's will sound MUCH better than the 4x6's
Good luck
Alex
Good luck
Alex
1 Post
It's pretty straight forward, there are heating/AC ducts near the speaker that will get in the way if a speaker with a larger depth and magnet are used. Simply take a heat gun, heat them up, and bend them out of the way until you can fit the speaker you want in there.
Engine: L31 350
ok, thank you, my passenger side kick panels loose anyways so ill do this soon, thank you guys for the help
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Thanks.
1 Post
Ice on the out side might make it worse because of the drastic temp difference. I actually used a very expensive soldering iron that gets REALLY hot, just molded small sections at a time and didn't get my windshield hot.
1 Post
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
6" speakers fit my '86Ta without too many problems. Passenger dropped in, but I needed to do some slight trimming on the drivers side. The dash is pulled out easily.
Be sure the speakers are not too tall and try not to let the tweeter cone sit above the speaker as they will contact the grill.
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
db057
08-11-2015 10:11 PM
