wiring help. extremely confused
Old Mar 7, 2010 | 05:31 PM
Xx89CamaroRSxX's Avatar
before you say search i would but the seach thing wont work and im kinda in rush because its getting dark. i havent had a radio in my car for idk how long now and its driving me crazy. i even went out and bought a new radio today.
apparently the friend who had instead of buying the harness adapter he cut the factory wires so now i just have a bunch of wires where the cd player should be. the speaker wires are pretty much self explanatory. i hooked the yellow wire which i beleive is switched 12v to the yellow wire on the cd player harness then i hooked the orange wire which i beleive is constant 12v to the red wire on the cd player harness and i hooked the black wire which obv should be ground to the black wire on the cd player. now with just those wires plugged in minus the speaker wires when i turn the key the cd player makes a noise like its checking if a cd player is in then does nothing. it never once lights up and theres never once any music. i checked the radio fuse under the dash and it was fine and i put a new one in just to be sure. im completly stumped right now and i have no idea what to do?!!?!? its been all weekend and nothing. if someone could help me that would be amazing.
Old Mar 7, 2010 | 06:21 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: wiring help. extremely confused
radios is broken sounds like
Old Mar 7, 2010 | 06:29 PM
i thought so. bought a brand new radio today. does the same thing
Old Mar 7, 2010 | 06:33 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
dbl check ur wiring:
Constant 12V+Orange
Switched 12V+Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Right Front Front Speakers4" x 6" DashLeft Front (+)Tan
Left Front (-)Gray
Right Front (+)Light Green
Right Front (-)Dark Green
Rear Speakers6" x 9" Side Panels
Left Rear (+)Brown
Left Rear (-)Yellow
Right Rear (+)Dark Blue
Right Rear (-)Light Blue
I would start by only hooking up power
Old Mar 7, 2010 | 06:44 PM
see thats what i tried. i ignored the speakers. now the brown gray and pink? those hook to nothing? because my cd player doesnt have wires for that. most cd players i see dont. but idk im thinking maybe theres a ground problem with the ground wire but i cant find my check light to test it >_< its quite aggravating
Old Mar 7, 2010 | 06:50 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
ground it directly to the chassis and try it.
ok so i just realized where my check light was and i ran out there real fast. heres how it went.
White light -is when tester touches nothing.
red light - is power
blue - is ground
when i touched the yellow wire with the key in the on position the yellow wire gave a red light. when i touched the ground wire it turned blue. but when i touched the orange wire the light stayed white. it seems the constant is not working.
and way to bypass this or figure out where the problem is?
Old Mar 7, 2010 | 06:52 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
check ur fuses, that constant should be the same as ur power to ur lighter iir
whoops double post
Old Mar 7, 2010 | 06:55 PM
i checked the fuses in the beginning. the radio fuse was broken and i replaced it and it still did nothing.
obv my check light worked so the lighter socket works. im really at a lost right now.
Old Mar 7, 2010 | 06:56 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
check again, bet it blew since
Old Mar 7, 2010 | 07:04 PM
ok just did and get this. the fuse isnt blown but when i use the check light on the fuse plugged into the socket it gets no reading the light stays white. however when i touch any other of the fuses i ether get the blue or red light. for some reason theres nothing going to the radio fuse? anyway to fix this or get around it?
Old Mar 7, 2010 | 07:10 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Any of the speakers blown? grounding out the system
Old Mar 7, 2010 | 07:17 PM
would that cause the constant not to get power? and idk ive never had a radio in the car since ive had it so idk the condition of any of the speakers. howd i check this without a cd player being able to hook up?
Old Mar 7, 2010 | 08:36 PM
cdoyle's Avatar
So you don't get 12V on either side of the fuse? Have you tried replacing the fuse, just to make sure it's not one of those fuses that look good, but are actually bad.
If push comes to shove, and you just can't get 12v at the fuse.
You could run your own 12V constant line from the battery to the deck (be sure to fuse it at the battery). But I would try and figure out why it's not getting 12v at the fuse. Does your cig lighter work, i might be wrong, but I thought that was connected to that fuse too.
Old Mar 7, 2010 | 08:47 PM
firebirdbroni's Avatar
Car: 89 Formula WS6
Yeah it sounds like theres nothing going to the fuse. I would check that by hooking the cd player's 12V constant and switched to something you know has power (sounds like your yellow/ignition switched wire would do that). If it works then its time to check the fuse box for loose wires.
Old Mar 7, 2010 | 08:50 PM
the fuse is brand new i bought it today and i have one of those little fuse testers and its good. like when the fuses are in the fuse box i prode them with the tester. all the fuses ether give me a ground light or a power light except the radio one i dont seem to get anything from it. even if i switch a 10 amp from somewhere else on the fuse box that works. and yes the cigarette lighter works because i used my test light. it plugs in a cigarette lighter. idk whats going on. its quite aggravating. the yellow wire gives the power light and the ground gives the ground light but when touching orange nothing. what im thinking is maybe theres a cut or something in the wire somewhere under the dash. so maybe 2 morrow ill try to follow the wire and if i find something just replace. or ill be running the wire to my battery.
Old Mar 7, 2010 | 10:27 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
just run the 12v constant directly from the batt. (with a inline fuse off course) . the 12v constant(orange) going out seems to be a very common problem, with an apparently impossible to find fuse problem.
Old Mar 8, 2010 | 07:57 AM
Is there possibly anything else that I could splice into other then running it staright to the battery? That's not to hard to get to ether? I mean I'll do it if i have to but I rather run the wire somewhere else
Old Mar 8, 2010 | 08:36 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
better to do it from the batt. that way you will also have better wiring. i did mine in 12gauge. cost is roughly 6 dollars to do.
Old Mar 12, 2010 | 05:15 AM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
the wiring is backwards on these two wires. the new radio needs 12 volts constant on the yellow wire and 12 switched on the red wire. see if that makes a difference
Old Mar 12, 2010 | 06:57 AM
what I know is the orange has no power running through it. I checked it with the check light and it's dead. I'm assuming the wire is cut or chewed somewhere (at one point had mice in the car). I went ahead and wired a new power wire to the battery but here's my new problem. The radio works but doesn't save any presets at all. So would your idea fix this? Cus as of right now the power wire is attached to the red wire on the radio and my yellow wire is attached to the yellow wire on the radio.
Old Mar 12, 2010 | 11:36 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
you have it backwards. attached the power wire to the yellow wire, are you using an aftermarket harness? or did you cut ur cars harness?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
