Please help me identify what this is???
Old May 16, 2010 | 12:36 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Back of my factory radio 87 iroc..I know one is for clock power and the other is a ground(or similiar). But what are the little red clips?? and also if it has a push in connector then what are the little pigtails for that where cut
Old May 16, 2010 | 12:44 PM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
Re: Please help me identify what this is???
If I had to guess from the pics, it looks as if somebody tied into those wires to power something else. Doesnt look factory to me. If there is one wire on one side of the clip, and two wires on the other, then Im positive its just a jumper wire put there by a previous owner...Unless of course you have owned it since new...
Old May 16, 2010 | 12:52 PM
Twin_Turbo's Avatar
Those red clips are called scotch blocks, they have a little blade that cuts into one wire and allows you to splice in another. they are a guarantee for electrical gremlins.
Here you can see it before installing.
The original wire goes into the inner through and through hole, the other wire goes into the other hole which is blind on the other side and the blade cuts in both completing the circuit.
There are several styles of these, incliding one that looks like a C with a spade terminal at the end. Those come w/ MSD boxes.
Old May 16, 2010 | 03:27 PM
Engine: 350TPI
so these scotch blocks werent factory is what your telling me?? somebody probably thru these on when they hacked the radio to death??
Old May 16, 2010 | 03:33 PM
Twin_Turbo's Avatar
exactly, they were someone elses handywork. Remove them and if the connection needs to be there for some reason (aftermarket item installed), solder & heat shrink the connections.
Old May 16, 2010 | 05:26 PM
Old May 16, 2010 | 09:36 PM
Engine: 350TPI
Nope connection dosent appear to be needed . although he did say something about having a draw on the system that him and Multiple dealers could not find!! so he installed a kill switch on the battery. maybe he jumped straight to negative around the kill switch so the clock would always be powered like intended.. How much power does a clock draw on these stereos??
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
