Monsoon Lights dont appear! AHH
Old Jun 13, 2010 | 01:26 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
So I recently swapped out my GTA head unit for one out of an 01 S10. Now it fit in nicely and looks good, plugged in fine except for the wheel control plug, which I expected.
Now, the button lights do not come on at all.
Any ideas are greatly appreciated!
Old Jun 14, 2010 | 09:40 AM
FalconZ28's Avatar
Car: 1986 Corvette, 1985 Z28
Engine: 383 Vortec HSR, 350 Vortec TPI
Transmission: 700-R4
Axle/Gears: 3.83
Re: Monsoon Lights dont appear! AHH
You might be able to look up the wiring diagram for the S10 and find which one of the steering wheel controls gave power to the lights in the head unit.
My first guess would be that you would need to fabricate a power source into one of the ports on the wiring harness for the old steering wheel controls in order to get the lights to come on.
Good luck!
Old Jun 14, 2010 | 10:58 AM
Stangski09's Avatar
You think the steering wheel controls is the power source? Because the clock and the pwr light up.
Old Jun 28, 2010 | 11:40 AM
FalconZ28's Avatar
Axle/Gears: 3.83
Most likely there is a separate power source for the lights on the steering wheel. It doesn't make much sense, I know, but that's just GM for ya. Always cutting corners to save half a cent.
Old Jun 28, 2010 | 04:01 PM
Stangski09's Avatar
You know i'm talking about the buttons on the deck arent lighting up. I found a harness for the steering wheel controls, so you figure I have to pin my existing steering wheel control harness into this new one?
Old Jun 28, 2010 | 04:19 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
you need to get a wire colorcodes for the s10 and make sure........ill see what i can dig up for ya
Old Jun 28, 2010 | 04:27 PM
89RS_82Z's Avatar
ok here ya go
the S-10 is like so
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
your car is
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
i would make sure the illuminstion and dimmer are connected right
does the display dim when you turn the lights on, if it does and the keys do not light then the bulbs are blown
Old Jun 29, 2010 | 01:51 AM
Stangski09's Avatar
Ya, the display dims. I found the exact same deck at pick n pull today, so i'm going to exchange mine and try out the other one.
And i'm thinking, my GTA has 3 different plug ins, 2/3 plug in and I always assumed that the other one was for the wheel controls, but maybe it's the light bulb power source?
Because I did try an 93 Bonneville Cassette Deck before I picked up the CD Deck, and the lights didnt come on either, just the display.
I hope the bulbs are just burnt out.
Guess i'll find out tmrw.
Now I was looking at this adaptor
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Because the clear looking adaptor looks like my wheel control harness would plug right into that?
Because a guy with an 89 RS used that on his deck.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
