Replace Delco tapedeck with modern player
Old Aug 8, 2010 | 06:27 PM
Moe87's Avatar
I currently have an 89 trans am GTA w/ the radio control steering wheel.
The current delco tapedeck installed is a Model 16062322.
i am looking for a few compatible modern day mp3/cd/aux jack based players to replace it with. Looking to keep as much stock in place as possible so using the same wiring is a HUGE plus.
if you guys have any suggestions or tell me what you are using, id really appreciate it!
Old Aug 8, 2010 | 08:48 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Replace Delco tapedeck with modern player
I would think one of the Monsoon decks by Delco would be pretty much plug and play. Your 89 should have a 20-pin connector that looks something like the picture below with an open 6-pin section. For you, that open 6-pin section may have a single wire in it for your steering wheel controls.
This is from a Delco Theft-Lock CD player, the single green wire is for a SCV (speed controlled volume) that I haven't got to work yet. Steering wheel control input is very close to that, I forget which pin, but I can find out if you end up with a similar radio. BTW, the Monsoon deck would match the interior of your GTA.
Old Aug 8, 2010 | 09:40 PM
Moe87's Avatar
yes my delco has the 20 pin connection
[......][....] with the two pin connector.
Does the delco you suggest have an aux in port? im really looking to connect my zune and bypass a casette adapter that makes the most horendous static noises, even after cleaning the unit.
edit: just saw your previous https://www.thirdgen.org/forums/car-...elco-head.html ill be contacting the guy about the monsoon for pics, etc. thanks for the advice.
Old Aug 9, 2010 | 08:44 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
I've added an auxiliary input to my tape deck :
https://www.thirdgen.org/forums/car-...ary-input.html
sailtexas186548
Jan 19, 2016 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
