Having trouble wiring my new deck 82 z28
Old Aug 13, 2010 | 10:45 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Hey all, im having a troublesome time wiring my new deck in my camaro, I cannot quite figure out why it wont turn on, i have wired the power 12v, and the ground, now i cant figure out the ignition wire to activate the deck. I think it should be this one grouped with the power harness plug, 3 wires lead into that. Ideas?
Old Aug 13, 2010 | 11:13 PM
Heavy_Chevy's Avatar
Re: Having trouble wiring my new deck 82 z28
if you can't find it with a test light...check all your fuses...the one you need may be blown...if not it's probably gonna be harder to trace the wire and find the problem than to run a new wire. on my fuse block (it's an 89) it has a blank spot marked acc...check it with a test light it should be hot with the key on...get a length of wire and make sure it's long enough to reach..use a spade connector to plug it into the fuse block...i would suggest running an inline fuse unless you are just ballsy...it's your call hope I helped.
Scott
Old Sep 3, 2010 | 03:14 PM
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Old Sep 3, 2010 | 05:57 PM
Engine: 357
I got it, apparently the guy who had it before me removed the acc power wire? lol. spliced in some new wires and shes good to go
Cleotiz
Jan 6, 2018 08:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
djmarch
Aug 19, 2015 12:07 PM
rithsleeper
Aug 11, 2015 07:55 AM
