huge noob, wiring help.
Old Sep 5, 2010 | 04:10 PM
romeomeo's Avatar
Just got a 92 Camaro. never really done any car audio before. everythings stock right now. there was a radio / cassette deck sitting in the slot but nothing was plugged in and a couple cables were cut from it. here's a picture of the cables loose right now, could anyone push me in the right direction to installing a deck? Thanks
Old Sep 5, 2010 | 06:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: huge noob, wiring help.
All stereo wiring has been pretty standard for many years - whatever stereo you get the instructions will tell you what wires are what - or if you don't have instructions go to the website for the stereo manuf and they should have downloadable instructions.
For example - that blue connector - That dark blue wire is usually a remote wire (like for a seperate amp). That white plug is all speaker wires - brown is one side, green another, etc. It's all standardized wiring, so looking at any stereo wiring diag will tell you the function of each wire.
But - you can get wiring adapters at Best Buy, Radio Shack, etc. that give you plugs for your head unit that just plug into the factory harness so you don't have to cut the wires.
Old Sep 5, 2010 | 10:00 PM
sakattack28's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
you should be able to get the wiring harness very easily. i dont have any pics right now, but i might be able to get some, if you dont know what camaronewbie is talking about. its nice because you can plug those three connectors in to one end and the other to your aftermarket headunit with out hacking wires to bit, makes it much easier if you, or the next owner should you sell it, if you need to change something. go to your local autozone, advance auto, pep boys, radio shack or which ever and in the car audio section you need to look for a wiring harness adapter for your year of car (it will be a range) and that its gm. that easy. i suggest looking at a car parts place first, as they defiantly will have it, and most likely cheaper than best buy.
Old Sep 6, 2010 | 12:37 AM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Any walmart should also have the harness plug its very simple to install the stereo yourself. You just plug one end of the harness you get from walmart or wherever into those three plugs currently in your dash then splice the wires on there to the wires coming out of the plug in the radio. If you need any help figuring out which wires go to what get the model number on your radio and look up the manual on the internet. Give us a holler if you need anything else and welcome to TGO.
Heres a link to the exact harness you would need.
http://www.crutchfield.com/p_1207018...s.html?tp=2977
Old Sep 6, 2010 | 04:00 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Go to walmart buy a Harness plug that plugs into those and wires to deck...
then your done
Old Sep 6, 2010 | 10:35 PM
Car Lover's Avatar
Car: 1989 Firebird
Engine: 350 TBI
Transmission: 700R4 (Sadly)
Axle/Gears: ?.??
Here is a wiring Diagram that works for most GM Cars, helped in my car.
File Type: pdf
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
Bull86
Aug 10, 2015 05:43 PM
