Amp and Sub box?..
Old Aug 2, 2010 | 08:27 PM
f18pilot5's Avatar
Car: 1992 Camaro RS
Engine: 355
Amp and Sub box?..
does anyone have a good amp and sub box? if so where did you get it and post a picture...
Old Aug 4, 2010 | 08:22 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Amp and Sub box?..
here's the old setup I built, definitely would do it again (single 12" + amp)
Old Aug 4, 2010 | 10:45 AM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
wow my friend and i just built my box over the weekend still need to install the power cable put carpet over mine, i have two tens and a 1500 watt amp. and hey dan how in the hell did you get a twelve to fit like that my set up is just like yours but i have my amp rlse where and two tens
Old Aug 4, 2010 | 10:55 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i started off with the 2x10" schematic that's floating around the car audio section here and went from there. I only built the lower section and then carefully measured and built out the sub side. here's a better shot of the box layout without the top to give you a better idea. Unfortunately, the box is long gone, so I can't get any new measurements.
Old Aug 4, 2010 | 11:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Maybe doesn't work so well if your looking for a ton of widow-shattering neighbor-waking please arrest me thump ...
But I just made the 'cover' - installed a 10 (2 12's would have easily fit - I used 12" speaker grills), and it rests on the little 'shelfs' on each side of the rear. In the end, it looks just like that above - I just mounted my amp under the board instead of on top for a nice clean look. It's just 3/4 mdf cut to fit in the rear and rests on the shelfs back there. Under I have plenty of room for my power inverter, small tool bag, jumper cables, and the wife's purse gets hidden under at the carshows/cruise-ins.
http://i287.photobucket.com/albums/l...92RS/logo1.jpg
Old Aug 4, 2010 | 04:17 PM
f18pilot5's Avatar
Car: 1992 Camaro RS
Engine: 355
i got 2 kenwood 12's. im looking for a premade box if you guys know where i can get a good cheap one..
Old Aug 4, 2010 | 09:52 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've got one similar to the one Dan has pictured. It's custom made from MDF and fiberglass and loosely based on the dimensions of the diagram in the stickies. It also has a carpeted cover made from expanded metal to conceal and protect the amp and sub.
Old Aug 4, 2010 | 11:04 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
that looks pretty amazing
Old Aug 6, 2010 | 02:10 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Looks like Al has MOJO
Sweet install
Old Aug 6, 2010 | 02:12 PM
Car: '90 Camaro
Engine: 305 tbi
how do u keep your amp cool?
Old Aug 6, 2010 | 03:09 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Wow guys! Nice boxes! looking great!
Me and my dad built mine from old wood we had sitting in the garage. Just made some measurements and did some pretty smooth cutting. Then we used a utility rug with rubber on the bottom for the carpet on the box. We stick it to the box with 3M adhesive. It sounds great so far! i only got one sub in it at the moment, But it still shakes the car with just a little MTX. And the rubber prevents any rattling or anything,like Dynomat would. Heres some pics:
Old Aug 6, 2010 | 04:35 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Here's a link to the write up I did when I built my box, its made from 3/4" MDF, houses two 12 inchers and slants towards the front of the car.
https://www.thirdgen.org/forums/car-...imensions.html
Old Aug 6, 2010 | 08:32 PM
Al Hasse's Avatar
Sweet install
That big heat sink on the top does a nice job, the fins are open to the air, even with the cover over the sub & amp.
Old Aug 8, 2010 | 11:24 AM
Car: '90 Camaro
Engine: 305 tbi
sorry im no audio expert lol but whats a heat sink?
Old Aug 8, 2010 | 12:35 PM
Al Hasse's Avatar
The whole housing of the amp is fashioned into a heat sink for the power transistors to mount to. When they heat up, that heat is absorbed by the aluminum of the cover and dissipated into the air by the fins in the cover. Granted, it would work better if I had some air circulation with a fan
http://en.wikipedia.org/wiki/Heat_sink
Old Aug 8, 2010 | 03:42 PM
Car: '90 Camaro
Engine: 305 tbi
o ok, well i just got all my stuff hooked up today it sounds great and its not ported but its sealed but i was thinkin of hiding my amp where my spare tire goes but i was scared it might get to hot
Old Aug 8, 2010 | 07:18 PM
Car: 1991 RS Camaro
I mounted mine in the spare tire area and i actually think that keeps it cooler than if it were in the car. I did remove the spare though and mounted it on an mdf panel using the threaded holes where the jack and everything screws in.
Old Aug 22, 2010 | 09:57 PM
86Zguy's Avatar
Car: 1986 IROC-Z, 1984 C10
Engine: 5.0 305 V8
Transmission: 700R4 Auto
i went with a truck box from best buy, cut a peice of plywood covered it in carpet and droped it in i have the amp on the raised end heres a pic
Old Sep 6, 2010 | 10:45 PM
Car Lover's Avatar
Car: 1989 Firebird
Engine: 350 TBI
Transmission: 700R4 (Sadly)
Axle/Gears: ?.??
You can buy a box off of eBay like this one for about 50 dollars, it was 30 dollars for shipping to IL so 80 and you go yourself one of these. This is just a pic of the subs just dropped in i have to install it yet and the amp is not going on the box due to vibrations. I'm in Afghan so that's stalling me and my little bro took the pics and placed the amp there.
Old Sep 7, 2010 | 12:11 AM
f18pilot5's Avatar
Car: 1992 Camaro RS
Engine: 355
damn that looks really slick! i finaly gave in and folded my back seat down and put a normal box in next time i get some good money im guna put that kind of box in.
what kind of amp is that?
Old Sep 7, 2010 | 12:09 PM
Car Lover's Avatar
Car: 1989 Firebird
Engine: 350 TBI
Axle/Gears: ?.??
Its a Rockford Fosgate Punch P400-1. Its a mono amp 400w and its tiny, only 9"x7.5" so smaller than a sheet of paper. The box just drops in and you even have some space under it in the hole to put things, works for me. The box stops like right by the ledge if you can see it in the pic. Each chamber is 1.56 Cu.ft. so just have to make sure your sub doesn't need more and the Word attachment has a picture of it with all the dimensions.
File Type: doc
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
raymondandretti
Sep 27, 2015 06:43 PM
