cant seem to find a head unit that im looking for.
Old Nov 13, 2010 | 08:48 PM
dans89's Avatar
Car: 85 z28
a few years back, there was a guy on a VW forum that had an alpine head unit that was a NAV style/touch screen that had a 6 or 7 inch screen. this HU also came with a HDD. and he had the HDD mounted below the HU. i cant seem to find any thing about it. anyone know anything about these??
edit: and IIRC it also had a nav system built in. i remember him talking about splicing into the VSS to wire it up.
Old Nov 16, 2010 | 10:55 PM
dans89's Avatar
Car: 85 z28
Re: cant seem to find a head unit that im looking for.
anyone???
Old Nov 17, 2010 | 08:15 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
can't seem to find anything in alpine's current catalogs, so it looks like you're gonna be stuck searching the car audio forums or ebay. if you're set on having a hard drive, you can always get a USB-equipped model and use an external. I've also seen quite a few of the double dins with sd card slots too
Old Nov 17, 2010 | 08:56 PM
dans89's Avatar
Car: 85 z28
not really too set on having a hard drive. just a nice feature i guess. thanks for the reply. i also thought about building a "carputer" does anyone know if it can be linked directly to the ecm for data streams and tuning?? im planning to do an LS1/T56 swap.
Old Nov 17, 2010 | 10:11 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
i know when you build a carputer you can hook into the OBDII and they don't work with OBDI (82-92 fbody's) at least when i was looking into them
I haven't seen a head unit that does that. But once again i didn't look into that to much on head units, and it was a while back.
But i can almost certainly say a head unit that does that is going to be upwards of 1000, Which makes a carputer seem budget friendly.
Old Nov 17, 2010 | 10:27 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
Most manufacturers stopped making units with hard drives approximately 2-2.5 years ago. I personally like them too, have you ever seen the Pioneer Z3? It's a sick unit. Instead they are making units now with more options built in and deleting the hdd feature to make them more affordable. You can find some really nice navs/head units now like the Kenwood, Pioneer, and Alpine.
Old Nov 17, 2010 | 10:34 PM
Brendan91Z's Avatar
Axle/Gears: Stock
Car computers are cool too. I haven't seen one that can be connected with the ECM, but I'm sure it can be done. I have experience with them and have installed a few and you can do it for the same cost as buying a navigation unit. If you have questions let me know and I can help you out.
Old Nov 18, 2010 | 12:47 PM
dans89's Avatar
Car: 85 z28
cool thanks ive been considering building a carputer for a little bit but i dont know if i will need all of the features. (i guess you can never have too many) one of the problems is i dont even know where to start.... is it like building a regular pc? i have a little bit of experience building desktops. and can you still have features like AM/FM radio, cd changers, ipod interface, ect. because i still want to have all of the features of a regular HU, and if i could learn how to tune i think being able to do it in the car would be awesome.
Old Nov 18, 2010 | 02:53 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i had a carputer a while back, looking to build another one over the next couple years. prices and sizes have come down a lot (pico-itx comes to mind) while increasing processing power and features keep increasing. Lucked out that I've got a 4th gen dash and a big open spot on the passenger side where the airbag was.
a car pc can get quite involved, but determine what you want and go from there. easiest route would be to stick with a headunit to keep the am/fm tuning and processing (crossover, eq, etc) and just input the pc's audio into the deck as an aux. set up an lcd touchscreen monitor elsewhere.
or you could get 4+ channel soundcard and get software plug-ins to route the audio to various outputs, get a fm/am tuner card, and eliminate the headunit completely.
a usb odb1/2 scanner should be easy to work into the setup, but viewing little data cells could be bothersome on a small monitor.
Old Nov 18, 2010 | 05:18 PM
dans89's Avatar
Car: 85 z28
ok i see. do you know any sites where i could check out stuff for them?? any sites out there like newegg.com or tigerdirect.com have stuff for them? im kinda interested.
Old Nov 18, 2010 | 07:37 PM
Engine: LB9
Have you looked around mp3car.com? Seems to be the goto place. The thirdgen.org of carputers
Old Nov 18, 2010 | 07:44 PM
dans89's Avatar
Car: 85 z28
ill check that out thanks.
Old Nov 18, 2010 | 07:46 PM
Shadow Z's Avatar
Car: Lots of 'em
WTF! I just posted a picture of my Kenwood KVT-717 DVD flip out head-unit with the 7" LCD touch screen in the whole "weirdest thing you've found in your car" thread. Then, I clicked new posts and saw this!
Dude, I'd have no clue where you could get one, but I have one. I bought an '01 Mustang GT yesterday, and it came with it.
EDIT: Oh yeah, mine has an option for navigation, too. I just wouldn't know how to wire it up.
Old Nov 18, 2010 | 09:48 PM
Engine: LB9
Probably just an optional kenwood module that plugs in the back of the deck? like they do with bluetooth and such on kenwoods/pioneers
Old Nov 18, 2010 | 09:57 PM
dans89's Avatar
Car: 85 z28
those are cool but i dont like the flip out style. i like the regular touch screen ones that sit flush in the dash.
Old Nov 19, 2010 | 12:14 AM
Shadow Z's Avatar
Car: Lots of 'em
I'm not sure if a flush mount screen that size would even work on my Mustang, let alone the Camaro's even smaller console area. Then again, I'm not really into audio/electronics, so I know next to nothing on the topic. At least I'll be leaving the interior and radio in the Mustang, unlike what I did with the Camaro, in the name of weight savings.
Now since I've accomplished owning both cars in the biggest car rivalry of all time, I should step it up to the big leagues. Lamborghini Gallardo LP 560-4 Vs. Ferrari 458 Italia! Time to start saving! LOL.
Old Nov 19, 2010 | 10:57 PM
dans89's Avatar
Car: 85 z28
haha.... let me know how that works out for ya... and while ur at it ill send you my christmas list =). and back to topic i am planning on doing a 4th gen interior swap along with the LS1/T56. and from what i understand the 4th gen dash has a bigger radio hole. and if i doesnt i can always make a bigger one.
Infested
May 22, 2018 11:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
