Need audio help
Old Nov 25, 2010 | 05:00 PM
Firebirda7x's Avatar
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
Need audio help
I know nothing of car audio, and the kid before me has a Bazooka tube wired in. Thanks to the search feature I now know I have I think...4x6's in dash and 4x6's in sails and 2 5 inch subs in sails right? I have the "Premium Sound system".
My right rear speaker blew, and I figured I'd just replace everything. After some more reading this justs get complicated with stuff called crossovers and 3 channel whatevers and stuff. I'm pretty ignorant when it comes to audio...anyone able to just make it simple for me? Just want replacement speakers and subs that will sound good. I have a crappy Jenson deck in right now, btw. It says it's 200 watts. I am pretty good with electricity, just never done audio work aside from wiring in a radio to my 95 Escort. That's pretty much the extent of my knowledge for sound systems
Old Nov 25, 2010 | 05:46 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Need audio help
you have 4x6s in your dash from the factory, you have 6x9s in your rear sail panels, and as far as i know you cant get any subs in your sail panels, and they didnt come factory
Old Nov 25, 2010 | 06:06 PM
Engine: Chevy 355
Re: Need audio help
I got my info from https://www.thirdgen.org/forums/car-...nd-system.html
What is the point of a Premium sound system then? Other sites have said I have the 6 speaker setup as well...
Old Nov 25, 2010 | 06:27 PM
Engine: L31 350
Re: Need audio help
the premium system was a boss setup, it had factory amps, kickpanel speakers, speakers in the rear hatch, plus your dash speakers and sail panel speakers
Old Nov 25, 2010 | 06:33 PM
Engine: Chevy 355
Re: Need audio help
I thought that was only Camaros...I didn't see any kickpanel speakers or hatch speakers.
Old Nov 25, 2010 | 06:41 PM
Engine: L31 350
Re: Need audio help
take the kickpanels out, you should see amps. more or less check your passenger side kick panel
Old Nov 25, 2010 | 07:03 PM
Engine: Chevy 355
Re: Need audio help
Removed passenger, nothing. with my radio on I only hear audio from the sails and dash. Granted the kid before me could have taken things out or something I guess...
Old Nov 25, 2010 | 07:07 PM
Engine: L31 350
Re: Need audio help
you would have seen cut wires....why do you think you have a premium system?
Old Nov 25, 2010 | 07:12 PM
Engine: Chevy 355
Re: Need audio help
Cuz I have the badge and RPO codes for it. I have the suspension badge too, and RPO codes.
Old Nov 25, 2010 | 07:18 PM
Engine: L31 350
Re: Need audio help
i have a premium sound badge too but i didnt have it...just factory speakers, all the cars came with them i think, its just an option out cars didnt get.
Old Nov 25, 2010 | 07:30 PM
Engine: Chevy 355
Re: Need audio help
I had read on this very forum that if it has the Gain slide bar and RPO codes it has it, and that the Camaros had the Boss setup while Firebirds had the amp setup...and you drive a Camaro, I drive a Firebird. So....
Old Nov 25, 2010 | 11:21 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: Need audio help
Okay so this is what i did
I bought Alpine Type S 4x6's for the dash and rear pillars. Easy install. The wires that are already hooked to the stock speakers and hook them to the new ones. Then take the screws and brackets you get with the speakers and use those to hook the new speaker to the factory speaker box. Theyre 3 way speakers with a movable tweeter. Next for the pillars,i bought 2 Legacy Midbass 6 1/2 inch subs. you gotta cut the hole a little bit bigger by hand. Not too hard. you MIGHT have to sacrifice the air hole though. Hook those to the stock wire too. These subs should come with screws and brackets also. Get an aftermarket stereo. On mine i have it set so the back speakers get more power. And i have 2 10inch MTX subs in the back of mine. heres some pics
PILLAR BOX!!!
REAR SUBS:
Midbass's:
Old Nov 25, 2010 | 11:38 PM
Engine: Chevy 355
Re: Need audio help
I read reviews online cuz my bud said to get Alpine Type Rs and only S will fit and people said the S isn't worth the money. How do they sound?
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
zayne0
Aug 24, 2015 07:22 PM
RamAirZ
Nov 17, 2001 10:35 AM
85ws6TA
Car Audio
25
Dec 16, 2000 05:24 PM
Todd 92 Z
Car Audio
Sep 11, 2000 08:24 PM
