Double din bracket question
Old Dec 30, 2010 | 01:56 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
I just picked up a double din from my friend. I did some searching and got an idea of the modifications/trimming needed to get it to fit right. However, I was wondering what mounting kit folks have used as a starting point. Any help appreciated!
Old Jan 5, 2011 | 08:59 PM
Car: 1986 IROC-Z28
Re: Double din bracket question
Friendly bump.
Old Jan 6, 2011 | 12:37 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I would like to know the same thing. More in the way of 2 din than 1. Bump
Old Jan 15, 2011 | 04:00 AM
Car: 1986 IROC-Z28
Dang, no one has a tip?
Old Jan 25, 2011 | 02:52 PM
Z28Johnny's Avatar
I'm looking for this info also. It looks like there is enough room to get a decent install of a double.
Old Mar 10, 2011 | 02:04 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
i started with aluminum brackets
Attached Thumbnails Double din bracket question-pj-3-9-2011   Double din bracket question-pj-3-9-2011
Old Mar 10, 2011 | 03:28 PM
Im sure there is enough room and I will try it that way. Will be nice to see the fitment from beginning to end. thanks.
Old Mar 10, 2011 | 04:20 PM
mudd746's Avatar
Engine: 305HO
first cut off rear support tab, heated vents to accomidate depth of new headunit, glued alpine trim ring to dash bezel
Attached Thumbnails Double din bracket question-pj-3-9-2011   Double din bracket question-pj-3-9-2011   Double din bracket question-pj-3-9-2011
Old Mar 10, 2011 | 04:22 PM
mudd746's Avatar
Engine: 305HO
routered bezel, filled in hole with abs and glue
Old Mar 10, 2011 | 05:37 PM
thanks. really helps to see these things as they happen. Great job.
Genopsyde
Nov 11, 2015 10:46 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
