what amp for 2 12"s`
Old Jan 5, 2011 | 10:08 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hey i been looking around for an amp for my 2 12" that i got for free and since i just bought a box for it today i was wonderin g how many watts amp would i need for them. These are the specs of my subs
Size12" Impedance2 ohms Cone MaterialPolypropylene Surround MaterialPoly-foam Ideal Sealed Box Volume (cubic feet)1.02Ideal Ported Box Volume (cubic feet)1.79 Port diameter (inches)4 Port length (inches)10 Sensitivity86 dB at 1 volt Frequency Response26 - 250 Hz RMS Power Range (Watts)50-250 Peak Power Handling (Watts)500 Top Mount Depth (inches)6 7/16 Cutout Diameter or Length (inches)11 1/16 Vas (liters)2.39 Fs (Hz)26 Qts0.55 Xmax (millimeters)11 and this is the amp i was thinking getting for them
http://cgi.ebay.com/ROCKFORD-FOSGATE...item5197162775
Old Jan 6, 2011 | 12:46 PM
87350IROC's Avatar
Car: 87' IROC
Re: what amp for 2 12"s`
What kind of subs are they?
Based on the specs, that amp would be plenty of power. 320W @ 4ohm.
Old Jan 6, 2011 | 03:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
They are rockford fosgate P2
Old Jan 6, 2011 | 04:02 PM
87350IROC's Avatar
Car: 87' IROC
You should be good to go.
Old Jan 6, 2011 | 04:22 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
double post
Old Jan 6, 2011 | 04:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
OK thanks for the help as for speakers do you know which are good
Old Jan 6, 2011 | 08:17 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i have an 800 watt pioneer mono amp pushin my two 12" sony xplods and its great
Old Jan 6, 2011 | 08:23 PM
Jaws031's Avatar
Car: 88 camaro
i you want to knock pics of walls when u drive by you need to get some l7 with a 1000 watt amp
Old Jan 6, 2011 | 08:39 PM
87350IROC's Avatar
Car: 87' IROC
320 watts is more than enough. For speakers I would recommend going to your local car audio store and testing a bunch. Speakers are personal opinion.
Old Jan 7, 2011 | 08:33 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
