hooking up head unit
Old Feb 3, 2011 | 12:06 AM
GREEK BANDIT's Avatar
Car: camaro iroc-z
Engine: 5.0
i just bought a new pioneer head unit and im wiring it all together just have a little question on the grounding. so the head unit has a black cable out the back with a little stakon to ground it to a bolt. I'm just wondering if the black cable on the wires in the car that attach to my adapter are also the ground cable. do i have to ground that black cable off the head unit or can i just wire it to the black cable already in the car because its already grounded? if not wheres the best place to ground the unit. thanks
Old Feb 3, 2011 | 09:01 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: hooking up head unit
i've seen a lot of the aftermarket decks have that ring terminal on the gnd wire, but you can usually use the factory gnd in the harness without issue.
Old Feb 3, 2011 | 06:04 PM
Car: camaro iroc-z
Engine: 5.0
ok ill giver a try see what happens. thanks
Old Feb 3, 2011 | 06:10 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Ok. Do we have all systems go?
Old Feb 3, 2011 | 06:43 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I always use the ground wire in the harness adapter.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ZsTransAm
Aug 11, 2015 07:30 PM
