getting through the firewall
Old Jan 23, 2011 | 12:04 PM
GREEK BANDIT's Avatar
Car: camaro iroc-z
Engine: 5.0
im looking for the best way to get my power wire through the firewall of my 87 camaro, just wondering if theres any tricks out there or if there is an existing hole that i missed. also the battery is on the passenger side and i was wondering if i should run the cable along the front then back to the firewall along the drivers side or run it along the passanger side then run it back across to the firewall that way. thanks
Old Jan 23, 2011 | 12:18 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: getting through the firewall
Where are you mounting your amp? Mine is on the passenger side, in the spare tire compartment in the quarter panel. My battery is also on the passenger side. My power wire (8 AWG) runs up to the kick panel, where I drilled a hole large enough, installed a grommet and fed the wire through, then fished it up from the cowl and continued forward to the battery. The wire runs along the top of the passenger fender and under any bracing.
Old Jan 23, 2011 | 02:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the driverside firewall sometimes has a couple extra grommets/plugs down low under the brake booster
Old Jan 23, 2011 | 02:13 PM
Car: camaro iroc-z
Engine: 5.0
well i was planning on putting my amp in the trunk mounted onto the sub box so and whats a grommet?
Old Jan 23, 2011 | 03:55 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Grommet is just a little rubber/plastic liner that goes in the hole. It keeps the jagged metal from scraping the wire and causing a short. They say that if you run your power wire with the rca cable it will cause some static or something like that. So I'd recommend you run the rca cables down the drivers side to the head unit. Then run the power cable down the passanger side and if you can't locate a hole just drill one pop a grommet in and your good to go.
Old Jan 23, 2011 | 05:57 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I ran my amp's power wire though with a new grommet through the antenna's hole.
Old Jan 25, 2011 | 11:42 AM
addicted2racing's Avatar
Car: 91 GTA
Engine: 383
Transmission: t-56
Axle/Gears: 9" posi 3:89 gears
Run power wire on same side as battery and RCA's and remote wire on oppposite. Makes more sense that way
As far as getting through the firewall i used an oversize grommet and drilled a hole big enough to fit 0gauge through and also sealed it with loctite polyurthene, Works great
Old Feb 3, 2011 | 11:57 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Thats the right way to do it in my opinion. The antenna wire goes through the passenger side kick panel. make sure you install an in-line fuse as close to the battery as possible to prevent any fires. A lot of car fires are started this way. Good luck!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
djmarch
May 8, 2016 11:32 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 21, 2015 10:28 PM
gta892000
Sep 16, 2015 12:40 AM
