box too small?
Old Feb 13, 2011 | 07:09 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
box too small?
can someone help me, iv got my 2 12" 1300 watt sony xplodes in my old SPX audio box and my uncle thinks the box is too small for them, can someone help me out? i dont know the dimintions of the box...
Old Feb 13, 2011 | 07:37 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: box too small?
We need the box demensions. Ported or sealed?
Old Feb 13, 2011 | 07:52 PM
Engine: L31 350
Re: box too small?
how would i get the dementions? and idk if its sealed or ported? explain, this is all new to me
Old Feb 13, 2011 | 08:05 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: box too small?
You need to measure the length, width and height of the box.
Does the box have any holes in it besides the hole cutout for the sub?
If it donesn't then it's sealed.
Old Feb 13, 2011 | 08:22 PM
Engine: L31 350
Re: box too small?
ported, and this box is slanted, so how do i measure the height and width?
Old Feb 13, 2011 | 08:29 PM
Car: 89 IROC
Re: box too small?
You need to measure box slants. Width won't change.
Ported could be an issue as usually it's tuned to the specs of the subs that were in the box. Maybe cover the ports and make the box sealed.
Need dimensions first.
Old Feb 13, 2011 | 08:31 PM
Engine: L31 350
Re: box too small?
well the spxs that were in there too begin with have alittle plastic circle in the back that the speaker wire ran from, i put those back in and installed the two square speaker wire connectors for my wire, i know i had to trip the hole alittle to be able to fit the sonys in there.
Old Feb 16, 2011 | 08:41 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: box too small?
to know what size is correct, you need to know the specifications of the subs you have now. a ported box is going to sound funny if its not built to the sub. if you're not sure how to measure dimensions and you don't have the sub specs, you may be better off sealing up the box and just running it that way. sealed boxes are a lot more forgiving on response than ported if made a bit off in size
GTAman
Jul 3, 2024 07:29 PM
Jorlain
Oct 8, 2015 01:57 AM
TrevinE
Sep 14, 2015 03:20 PM
64goatman
Sep 9, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
