Subs?
Old Feb 23, 2011 | 01:03 PM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Subs?
Whats the best way to have that extra kick a sub gives you without using a lot of space?
Old Feb 23, 2011 | 01:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Subs?
I took a piece of 3/4" board and simply made a shelf that just sits in the lower well on the small humps on each side. I have a single 10" sub mounted, with the amp mounted underneath, then i have 2 12" grills on the top - so it looks symetrical and like I have 2 subs when I only have one.
It's true that the best sound comes from a sealed box (unless you have free air subs), but this method works fine and I get a nice sound without rattling the windows on the neighbors houses.
Here's a pic: http://i287.photobucket.com/albums/l...92RS/logo1.jpg
Old Feb 23, 2011 | 01:55 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Subs?
to get the most out of a sub, you'll want build an enclosure that's correctly sized to your sub's specs. my last install used the bottom half of the well and a single 12" - still plenty of room for in the back for storage, t-top bag still fit without issue, and plenty of boom
Old Feb 23, 2011 | 02:31 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: Subs?
i thought about if someone did what the 4th gens have. in the back, on the side there is a sub box, leaving the hatch with as much room as it had stock.
i'm sure someone can cut the interior piece to have one fit.
Old Feb 24, 2011 | 05:38 AM
1991_RS's Avatar
Re: Subs?
Can You give me the dimensions of that i may build one in the future
Old Feb 24, 2011 | 08:04 AM
Convoy25's Avatar
Re: Subs?
i've searched around and from what i saw no one makes it themselves. they say the dimensions arent a fixed number, however i found some sites that have them.
http://www.keeaudio.com/enclosures.html
http://subthump.com/Chevrolet-GMC-Su...Enclosure.html <---- drivers side.
http://subthump.com/Chevrolet-GMC-Su...Enclosure.html <--- passenger side.
Old Feb 24, 2011 | 10:57 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Subs?
If you want to get creative, you can seal up the sail panels like I did and install a set of 8" woofers in there.
https://www.thirdgen.org/forums/car-...tem-under.html
They're not the loudest out there, but then I'm only feeding them about half the power they're capable of handling. Gives the system that little bit extra low that it was lacking, perfectly compliments the Pioneer 4X6 dash speakers. I also have all of my cargo space
Old Feb 26, 2011 | 04:19 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Subs?
3rd gen stelth box - you have to make it
Old Feb 27, 2011 | 06:24 PM
m00dy's Avatar
Car: 1987 Camaro, BMW e36 320i
Engine: 305 LG4 stock
Transmission: TH-700
Re: Subs?
For what concern audio quality, is this solution better than the other with sub placed down in a box (most of you have this solution).
Old Feb 27, 2011 | 07:50 PM
Car: 89 IROC
Re: Subs?
The sub can fire up or down (into the box). There is no difference in sound quality, but a sub firing up takes up less room and you can use a sub grille.
Old Mar 6, 2011 | 12:02 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Re: Subs?
did you do it for the passenger side? and can i get the dimensions and specs and what not b/c im seriously thinking of doing this myself. doing that does it rattle?
Old Mar 6, 2011 | 07:39 AM
Car: 89 IROC
Re: Subs?
It's not my car. You'll have to design the box if you want to make it.
Personally, I would put a single 10" in the very bottom of the trunk area.
Old Mar 6, 2011 | 12:12 PM
Convoy25's Avatar
Re: Subs?
i'm sure the passenger side would be easier considering you can just take that one piece off.
Old Mar 6, 2011 | 12:42 PM
Car: 1992 RS
Engine: Carbed 350
Re: Subs?
Pass side has the spare tire in there though.
I know I know ... I've not needed a spare tire in over 20 years either - but, with my luck, the minute I don't have a spare I'll have a blowout!
Old Mar 6, 2011 | 02:07 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: Subs?
lol ive never had a spare tire and ok ill look into making the side box.
Old Mar 6, 2011 | 02:21 PM
Convoy25's Avatar
Re: Subs?
i took mine out of both cars. i'm going to get a plug kit and a small AC compressor. saves room and weight.
plus AAA gives some piece of mind
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
