subs on the trunk hump
Old Oct 11, 2011 | 09:46 AM
mightydunk's Avatar
Car: 1990 Iroc-z Camaro
Engine: 5.7L
Transmission: Automatic
so i plan on installing 3 12" JL audio sub-woofers and was really thinking about trying to get them to fit on the hump in the trunk right behind the back seats any thing under that hump that wouldn't let me put 3 of them on it and what amp would you recommend for 3 12" subs my amp is a mini one that wont power them so i wont even try
Old Oct 11, 2011 | 06:06 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: subs on the trunk hump
Your gas tank is under the hump.
Have a look at this amp.
http://www.sonicelectronix.com/item_...RZ1200.1D.html
Old Oct 12, 2011 | 08:54 AM
mightydunk's Avatar
Engine: 5.7L
alright so i guess i dont want to run anything electrical into that huh? and that looks like a pretty good amp thanks
Old Oct 15, 2011 | 01:51 PM
mrrman's Avatar
nice amp...if i didnt have 2...Id pick this up....nice price to
Old Oct 15, 2011 | 02:10 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
There is right at 7/8" between the tank & the floor, so you can run wiring under the floor there if needed, but be careful drilling, obviously.
Old Dec 2, 2011 | 04:42 PM
Patrick Day's Avatar
I wouldn't run any thing under the hump, Just run your wiring down the driverside of you interior and threw the firewall.
Also why do you want to your speakers on top of your hump?
wouldn't that obstuct you rear view?
Old Dec 2, 2011 | 05:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
put it in the well. something that big will become very dangerous in an accident or if you have to stop quickly, especially because there really isn't anywhere that you can safely bolt it to on the hump.
Old Dec 4, 2011 | 11:09 AM
mightydunk's Avatar
Engine: 5.7L
I wanted to turn the hump into a sub box by cutting three holes in it and screwing the subs to the hump so that they would be in the holes that id cut in the hump instead of trying to fit them in a box in the trunk somehow
Old Dec 4, 2011 | 12:32 PM
Yes that would be a very bad idea, Your fuel tank is right there, besides you not having the room or depth needed . There is nothing to protect your speaker and your cables.
just build a sub box. its not hard. I made this one in just over two hours.
I never covered it but it sounds great
Attached Thumbnails subs on the trunk hump-016.jpg   subs on the trunk hump-014.jpg   subs on the trunk hump-020.jpg
Old Dec 4, 2011 | 01:07 PM
Car: GTA
Only 2 options to do that....A .75" thick subwoofer or relocating he gas tank. Obviously only 1 of those options could happen.
Old Feb 12, 2012 | 08:17 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
I did it. should be some pics of it on here, somewhere, maybe. No holes drilled, ran power down the passenger side on the interior. they point toward the back...hatch barely..i mean barely, closes. but it sounds decent. air volume was better in the well, but i was willing to sacrifice some sound for looks.
Old Feb 14, 2012 | 04:48 PM
Broone115's Avatar
im running 2 15" JBL's in a box mounted on top of the hump, its do-able with plenty of volume in the box for great sound, of course that all depends on what ur subs need but i think you can do it easily
Old Feb 15, 2012 | 05:43 PM
ZF6camaroZZ4's Avatar
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
I enclosed the back portion, was pretty simple. Kinda took the place of that sliding/roll up cover....
Anyway, had tried a couple different things. Settled on this back in 87.
Was running an Orion 4100 and 280 for amps, 15" and two 12" Cerwin Vega's.
CHP had my car impounded, then the amps were stolen
Running Orion 2150 and xtr2150 for the last 13 years I think. Same 15" and 12" CV's.....cv rebuilt them once.
Real nice everything is still holding together
Old Feb 15, 2012 | 07:50 PM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
Here's an older picture of my setup. Sun got to my amp trim and faded it. This winter I am buying new amps and sinking them into the amp board that these ones are currently sitting on. Should be a cleaner look and wont require the amp trim but still havent decided yet on how I am going to do them.
Running a Mono amp powering 3 12" Subs
4 channel amp powering 2 6X9's 2 6" round and 2 Q-forms up front for kick panels
Seems to be a fairly popular setup
Old Feb 16, 2012 | 01:35 PM
K. E. Christy's Avatar
Car: 1991 Z28
Engine: 5.0L TPI
Transmission: 5 Speed
..mightydunk.
This is how I addressed it with 2-12" subs with the amp under the box.
See pic below
Old Feb 16, 2012 | 01:51 PM
Car: 1991 Z28
Engine: 5.0L TPI
See pic
Old Feb 23, 2012 | 03:18 PM
Car: 86 Z/28 IROC-Z
Originally Posted by K. E. Christy
..mightydunk.
See pic below
How do you keep it cool? Even with cooling fans there were over heating..... just no air flow under there.
Old Feb 23, 2012 | 03:38 PM
Car: 1991 Z28
Engine: 5.0L TPI
ZF6,
I haven't so far in 10+ years and the car is Florida, but then again the car is not a daily driver either.
Old May 27, 2012 | 12:59 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
In my perspective its better to have a setup where the speakers are in a box in the trunk indention slanted a bit, helps the sound travel to the front seats.
Old Jun 6, 2012 | 02:51 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
You CAN, but from a personal standpoint, i'd hate to have all that flying toward my head if i ever rear end somebody at high speed.
Old Jul 25, 2023 | 11:17 AM
Iroc1988ThePas's Avatar
Hi, quick question, is this setup in a convertible?
Old Jul 25, 2023 | 11:20 AM
Hi, is this in a convertible? Thanks
Old Jul 25, 2023 | 11:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Patrick Day [img]/forums/images/buttons/user_offline.gif[/img]
User Lists [img]images/misc/menu_open_usercss.gif[/img]
Last Activity: 03-17-2012 03:41 PM
Old Nov 17, 2023 | 02:39 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
It can be done. This BARELY clears the glass. Good sound. Need to re-do the amp rack. Theory was to mount the amps up a bit with green neon behind, and backlight the camaro logo also in green neon but it just wasnt bright enough. Been like this forever. Debating re-doing the entire install in a year or two. For those wondering - no the speaker box isn't secured to the hump over the gas tank. Not sure if in an accident it'd fit between the seats and roof or not. But..i'm good with going down with the car in a crash lol.
Old Nov 23, 2023 | 07:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
And just to answer your question, that not a vert.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
