Pics of Sub Boxes Thats allow T-Top Storage
Old Nov 13, 2023 | 11:52 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I am looking into at building a sub box for my bird, I want to be able to strap my T-tops in place like intended. I will probably run one quality 10" so I am thinking I can recess it a little.
I am thinking I may want a small storage area on one side deep in the well for a small box of detailing products, a quart of oil etc....
Old Nov 13, 2023 | 09:10 PM
Abubaca's Avatar
Re: Pics of Sub Boxes Thats allow T-Top Storage
My t tops laid flat behind the rear seat, NOT in the luggage well like in a 4th gen. No reason you can't run a sub there.
Old Nov 14, 2023 | 10:40 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
that's not the route I want to go, I like my T-tops strapped in place where GM provided...
Old Nov 14, 2023 | 02:05 PM
Abubaca's Avatar
I feel like we're mis-communicating. GM intended them to lay flat, behind the rear seat, NOT in the luggage well. Now I'm certainly down if you don't wanna do that, but the reason I put it out there is because in your first post, you said you wanted to keep 'em where GM intended. If you wanna put 'em in the luggage well, more power to ya, but that's not where GM intended. .....and laying flat, leaves the luggage well open for a sub and a few other small items like you mentioned.
Old Nov 14, 2023 | 05:29 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I agree with Abubaca - sounds like there isn’t a meeting of the minds on this. Below is a picture of the factory t-top bag in a thirdgen hatch. The bag lays flat on the hump over the rear axle. This leaves plenty of room to install the stuff you want in the well area at the far back. My car in the pic below has a factory well lid that hides the recessed area. You could easily fabricate a flat board with a sub to look similar.
Old Nov 14, 2023 | 06:25 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I built a box for a dual voice coil 10" sub that fits down in the rear storage well. Made a carpeted cover board with a couple ports that lays flat over the ledges on each side. Looks good and a 10 is plenty with a good amp. I think I posted a couple pictures on here some years ago for that.
Old Nov 15, 2023 | 08:07 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
sorry guys, there's definitely a little confusion! I see a lot of sub boxes made that mount too high and obstruct the T-tops "laying flat" as designed, I want to build a box that is recessed enough not to interfere with them.
Old Nov 15, 2023 | 09:47 AM
Abubaca's Avatar
I think there is definitely enough room to do that, especially with a 10".
Old Nov 18, 2023 | 07:38 PM
theraymondguy's Avatar
This is a baffle board currently, like Tom3 had suggested. Supported by ledges on either side of the “trunk well”
plan is to convert to a ported sub box. 2 10” subs (isobaric push/pull).
lots of room for t tops, even after conversion to sub box.
Old Nov 19, 2023 | 10:31 AM
2slowfox's Avatar
Car: 91 Camaro RS
Axle/Gears: 4th gen rear
Custom made box for 10" sub and it doing the job
Old Nov 20, 2023 | 08:17 AM
Abubaca's Avatar
Slowfox, that looks really good! I've considered something like that myself. I've got the cnc router files for an 8" box. (I've got a big 3 axis router at work). Was gonna carpet the box and just cut out the plastic. The way you have the whole thing molded looks really sharp!!!!!!
Old Nov 20, 2023 | 11:37 AM
jimmylev's Avatar
Car: 89 IROC Vert
Engine: 5.0
Transmission: 5spd
very nice. Do you've any details on this enclosure?
Old Nov 20, 2023 | 03:39 PM
2slowfox's Avatar
Car: 91 Camaro RS
jimmylev, what details are you thinking of?
Old Nov 20, 2023 | 06:17 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Is the rear of that enclosure boxed(?) as well, or is it just the front and the car body is the rear?
Old Nov 21, 2023 | 12:32 AM
2slowfox's Avatar
Car: 91 Camaro RS
Old Nov 23, 2023 | 07:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
My old 84z, though i used the trunk well as a box since those old CW's are free air subs (12"). Used a hinge from a busted factory lid and the lock from my stock lid.
Old Nov 24, 2023 | 05:08 PM
kandybluez28's Avatar
Here is one from about 20 years ago. 1/2" mdf. 2 10's. Doesnt interfere with the t-tops. I've still got it but its due for an update.
TDIME479
Car Audio
Nov 26, 2011 02:20 PM
bminnix
Car Audio
May 20, 2009 09:38 PM
DonCamaro
Car Audio
Feb 14, 2003 07:18 AM
z28redline
Car Audio
Oct 20, 2002 10:08 PM
