Amp/ sub wireing question
Old Dec 19, 2011 | 06:28 AM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Currently my amp is under the drivers seat. where is the best place to pass thru the firewall with my power cable
Old Dec 19, 2011 | 12:03 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Amp/ sub wireing question
IIRC, on mine, I came in through the passenger fender where the wiring came through for the engine harness.
Old Dec 20, 2011 | 05:07 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I drilled a 1/4" hole in the firewall just behind and above the clutch pedal that came out in the engine bay by the clutch and brake fluid reservoirs. Before installing the power line, I insulated the edges of the hole to prevent the wire insulation from chafing.
The line runs from there along the top of the driver side fender to the battery. My amp is in the trunk and the line runs inside the car along the driver side to the new hole.
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
