Front Speakers Replacement
i just took the original front 4x6 speakers out of my 87 firebird because they where blown.
1. can i put any 4x6 speaker in there?
2. do they sell speakers that clip into the existing clip for the audio?
3. if they don't how would i install new speakers?
picture is of the speaker with the clip.
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Re: Front Speakers Replacement
I put a pair of Pioneer 2-way speakers up front in my GTA. With the supplied plastic bracket, they bolt in with the two factory holes, and kind of clip into the factory holder at the rear. No interference with the ducting setup in the dash. Here's a link at Crutchfield:
http://www.crutchfield.com/p_130TSG4...FBrand|Pioneer
I've also got a mint set of factory speakers for sale if you're interested.
-cal30sniper
-cal30sniper
Car: 1986 camaro iroc-z28
You have to make sure the speakers are not to deep maybe say 2 1/16" also you can put 4" instead of 4x6 just need to get a mount adapter. look at crutchfield's web site they will give you the sizes that will fit your bird.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Why don't you just put a new pair of originals back in,their still available.
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Look into a set of Boston Acoustics 746 plate speakers. I put these in my dash and IMO they're the best 4x6's you can get.
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Most 4x6 fit, if you use a 4" the adapter brackets are usually too tall. I never saw any for use with the stock audio clip I had to splice in an adapter.
Car: 92 FORMULA
Does anyone have a part# or recomendation to obtain factory original replacement dash speakers.I have a 92 Formula with the factory upgraded speakers(2 Ways?).AM/FM Cassette with 5 band EQ
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Weirdly, the part number varies depending on color.
These are your choices of colors:
- Black
- Medium Beechwood
- Red Flame
- Dark Gray
The factory speaker comes with a flat grille-cloth that appears to be integral with the speaker.
Car: 1991 Camaro RS convertible
Engine: 305 Tb
Transmission: 5 spd soon to be T56 6 speed
Axle/Gears: 3.08 soon to be 4.56
You can use JL 4 inch speakers.. they come with the 4 by 6 adapters.. Polk Audio alsol makes Slimline 4 by 6 plate speakers and 4x6 cone speakers
Engine: 5.0 EFI
GM PN/16033662 their all the same PN for 90-92 including UP8,U66.
http://www.partswebsite.com/gmpartsc...partnum=accept
F-SPEAKER
Make: Pontiac | Part#: 16033662
List Price: $57.26
Your Price: $34.64
If you go to a local GM Dealer they will charge you $57.26 ea.I recommend GM parts cheap.
F-SPEAKER
List Price: $57.26
Your Price: $34.64
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
You can put any 4x6" or 4" round speaker in as long as the mounting depth is not greater than 1-7/8" for mechanical speedo cars. Anything deeper and you'll hit the whatchamacallit on the back of the speedo. If you have an electronic speedo car you have more room for mounting depth but magnet width becomes an issue at that point because without modification you will hit the plastic ducting that runs under the dash.
If you order your speakers online from Crutchfield they usually supply a wiring harness that will plug into the factory speaker harness and has two female plugs on the end that plug into your new speaker.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
As a heads up Rockford speakers will not fit without serious modification, theyre over sized and way too deep. Pioneers, factory, or inifinity slims are a good way to go, or polk speakers with minor modification. Pop into your local reputable car audio shop and they (assuming theyre not crooks) will give you an idea of what will and will not fit
Engine: 5.0 EFI
The OP'S question was"
Does anyone have a part# or recomendation to obtain factory original replacement dash speakers'.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Whoa there snippy. Call me crazy but in the 5 years I've frequented these boards...."OP" is the original poster. As in post #1, the originator, the first guy to ask a question. So maybe you should trim that back a bit before you snap at someone. Don't get upset because someone jacked the thread and you contributed to it causing a confusion.
Car: 92 FORMULA
Sorry if I jumped on someone elses posting.Thanks for the info from Mantaguy and the info on replacement recomendations from every one else
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
Car: 89 TTA, 81 TTA, 05 GTO, 98 WS6 Form
Engine: 3.8T, 4.9T, 6.0LS2, 5.7LS1
Transmission: autos
Axle/Gears: 3.27,3.08,3.23,3.23
Opshesquishy,,,What did you use to modify the speedo case? I just bought a set of Infinity Kappa 4X6 speakers and was disappointed that they would not fit. I was not up for cutting anything at the time but I really love these speakers. Installing them in an 89 TTA.
I just laid the speaker in place, marked as best I could, then just shaved off the top of the speedo case.. I only needed a extra 3/8 of a inch.
Installing those speakers was the easy part of my build lol..
Transmission: autos
Got out my die grinder with a gnarl bit on it.. but any dremel tool with some sort of small cutting disc should work.
Thanks,,,,taking care of the problem tonight
db057
Aug 11, 2015 10:11 PM
