iPhone 4 compatible head unit
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I had been thinking about hardwiring an iPhone/USB charger so I wouldn't have to use the cigarette lighter for charging. However I realized that I have all my music on my iPhone 4 so I might as well get a head unit that is compatible with my phone, that way I can charge it and playback music. One thing I really don't like is seeing wires out in the open. I've been noticing that most head units that have an iPhone/iPod hookup, do so with a jack on the front of the deck. To me that's not acceptable, I'm looking for a head unit that has the iPod hookup in a remote location or through the rear of the deck. Does anyone have any recommendations?
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: iPhone 4 compatible head unit
There are tons of units that do it. Any unit that requires a "harness" will be using the rear of the deck for connections.
They also make units that allow you to put the iPod inside the head unit. Here's an example of one such unit: http://www.crutchfield.com/p_158DSXS...0.html?tp=5684
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
T Here's an example of one such unit: http://www.crutchfield.com/p_158DSXS...0.html?tp=5684
Car: 1987 camaro sc
Engine: lg4 305
you should look at the sony dsx-s100,200, or 300 is compatible with the iphone 4 and you will not see anything but the head unit the screen flips down and a tray pops out to put an ipod or an iphone in you control the music throgh the head unit. i am looking to get it for those features and it has good reviews
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
A good majority of the digital media decks support the iPhone now. I have a Alpine IDA-X300 series deck and it interfaces with my iPhone 4s perfectly fine.
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
I put a Kenwood KDC BT952 in mine and stream off my iPhone via bluetooth.
The flat black bezel and face looks slick and clean in the car as well.
ambainb
Apr 25, 2016 09:21 PM
