Need help with headlights 89 GTA fixed them, but now dont close all the time.
Hey..guys I have an 89 GTA and I just replaced the torque pins and the nylon gear and replaced the gear with an aluminum one. Now the headlights always, raise but don't always go down, they are totally intermittent in that regard, one will go down , both will go down, none will go down etc.. Does anyone have a clue why this is happening? BTW if you are own a third gen in Toronto I would like to meet, I have all kinds of questions. You can also reply to champam@hotmail.com
Thanks.
Mike C.
Thanks.
Mike C.
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Re: Need help with headlights 89 GTA fixed them, but now dont close all the time.
not sure if this will help but i have the same problem but i can always get them to close by pushing a little harder and the switch sounds stupid but works good luck
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
I have the same issue. I need to wait a moment and push HARD sometimes. I need to try greasing the hinges. Not sure if that will help being that they are moving at the same time.
Street Lethal
Apr 30, 2019 12:14 PM
The_Phoenix
Feb 4, 2016 07:10 AM
db057
Aug 11, 2015 10:11 PM
